AiM Cobra Motocross ECU Plug & Play Kit for Husqvarna
£480.00
AiM Cobra ECU Plug & Play Kit For Husqvarna
Cobra is the brand-new aftermarket plug & play ECU created by AiM, exclusively designed for off-road bikes. Thanks to its high technology 32-bit core, it represents an important step forward to improve the performance of your bike, without sacrificing reliability and smoothness.
Cobra Key Features & Advanced Strategies
Traction Control
Traction Control Strategy
Launch Control
High Technology 32-bit Core
Engine control requires precision. At 20,000 RPM the Cobra ECU guarantees the precision of 1/10 of degree: this means an accuracy within 0.8 use for turning the spark ON!
UC Bridge - Optional Extra
User License : A Cobra ECU comes with some basic maps that already give you better performance than the stock maps. Highly professional tuners all over the world offer specific maps that better fit your requirements, managing, for example, different exhaust, two injectors etc.
- Receiving diagnostic information from the Cobra ECU.
Tuner License :
Cobra ECU Connections
The Cobra ECU has 4 connectors :
Below shows a functional diagram of products that can added to the Cobra ECU:
AiM Cobra ECU Plug & Play Kit for Husqvarna
  • One low side driver (1 A)
  • Power consumption 150 mA
  • n. 1 33 pin male Connector
  • Body: PA6 + 30% glass fiber
  • Waterproof: IP67
  • Weight: 260g
  • Plug & Play ECU for Husqvarna
