SAME-DAY DISPATCH
on orders before 3pm
FINANCE AVAILABLE
on selected products
FIRST-CLASS SUPPORT
Aim Data Hub 4x CAN Connection Multiplier
£50
The Aim Data Hub, 4x CAN connection multiplier, works as an interface between all Aim loggers and their peripheral sensors. Available in two cable lengths.
The Data Hub 4x CAN Connection Multiplier, is used for the acquisition of all essential data you need to evaluate your car performance. It allows the connection of many peripherals to your data logger via one convenient cable.
Each Hub connects the logger with four peripherals: i.e. LCU lambda controller, GPS08 Module and one or more TC Hub (thermocouple multiplier) and takes all the information you need to your logger, with only one cable, minimising overall cables.
Data Hub is available in two versions:
Data Hub CAN connection multiplier 40 cm cable - X08HUB010
Data Hub CAN connection multiplier 150 cm cable - X08HUB150
Two way Data Hub
Dimensions: 70x30x23,5 mm
CAN cable length: 40 cm
Source cable length: 165 cm
Weight: 86 g
Waterproof: IP65
Four way Data Hub
Dimensions: 123x30x23,5 mm
CAN cable length: 40/150 cm
Weight: 97 g
Waterproof: IP65
