AiM Data Hub / CAN Expansion.
The AiM x 4 data hub with 40cm or 150cm cable.
Key Features:
The acquisition of all essential data you need to evaluate your karts performance needs the connection of many accessories to your data logger. This implies the presence of a great number of cables but the Data Hub takes all the information you need sent to your logger with only one cable, minimising wires overall. |
More Data Hubs can be connected in sequence in order to increase the number of peripherals which can be connected. |
AiM Data Hub 4x CAN Connection Multiplier with 5 Pin 712 Male Connector Kart
