Aim Data Hub CAN Car Connection Multiplier – AimShop.com
SKU: CAN-M-40
Availability: 12 in stock
£60.00
QTY:
Trust Badge
The Aim Data Hub CAN Car Connection Multiplier is used for the acquisition of all essential data you need to evaluate your car performance needs the connection of many peripherals to your datalogger. This implies the presence of a great number of cables.
To solve this problem, AiM developed Data Hub, the new CAN connection multiplier that works as an interface between all AiM loggers and their peripheral equipments.
Each Hub connects the logger with four peripherals: i.e. LCU lambda controller, GPS08 Module and one or more TC Hub (thermocouples multiplier).
The Data Hub takes all the information you need to your logger with only one cable, minimizing wires overall.
Data Hub is available in two versions:
Data Hub CAN connection multiplier 40 cm cable - X08HUB010
Data Hub CAN connection multiplier 150 cm cable - X08HUB150
Technical Specifications
Two way Data Hub
Dimensions: 70x30x23,5 mm
CAN cable length: 40 cm
Source cable length: 165 cm
Weight: 86 g
Waterproof: IP65
Four way Data Hub
Dimensions: 123x30x23,5 mm
CAN cable length: 40/150 cm
Weight: 97 g
Waterproof: IP65
