EVO5 Data Logger
AiM EVO5 Data Logger is the evolution of the traditional data logger that over the years has become a standard de-facto acquisition system in a huge amount of racing championships.
Key Features:
EVO5 samples all the information you need: Data coming from your ECU via CAN, RS232 or K-Line, from the internal accelerometers and gyro, and from the GPS08 Module included in the kit. From analogue / digital inputs, external expansions as well as predefined math channels. Sensors can be connected to 8 configurable analogue channels, to the RPM input and to 4 wheel speed inputs. |
You can configure the system and download your data over a secure Wi-Fi connection, even if your Car/Bike is 100 meters away from you.
The GPS08 Module included in the kit. Represents a true revolution in racing data acquisition. As soon as you start your track session you can immediately sample lap and split times as well as speed, position and acceleration. As well as all the information needed to tune your engine and help improve your driving technique. |
Add optional expansion modules via the built-in CAN bus:
Channel Expansion: Add an extra 4 0-5 analogue channels LCU-One Lambda Controller: Wide band Lambda controller LCU-One, with a Bosch LSU 4.9 probe, providing all air/fuel data, lambda value and exhaust gas temperature. SmartyCam Cameras: HD camera that overlays on video the data sampled by your logger. GS-Dash: Visualise all data being recorded by the EVO5 logger. |
Data recorded by the EVO5 can be downloaded to a PC and analysed with Race Studio 3 software. Showing graphs, histograms and tables will help you evaluate your performance. |
AiM EVO5 Downhill Bike Racing Data Logger
- ECU Connection: CAN, RS232, K-Line
- External modules connection: GPS Module, Channel Expansion, TC Hub, Lambda Controller, SmartyCam HD
- Analog inputs: 8 fully configurable - 0-5V, 0-12V, K thermocouples, Max freq 1 KHz each
- Digital outputs: 2 up to 1A each
- Second CAN: Yes
- Internal memory: 4 GB
- Connectors: 2 Motorsport
- Body: Anodised aluminium
- LEDs: 1 system status
- Dimensions: 114.4x47.2x58.8mm
- Weight: 300g
- EVO5 Data Logger
- 37 Pin Harness - Standard
- USB Cable
- Bracket with 2 screws
- User Manual
