AiM Exhaust Gas K Type Thermocouple.
Our AiM device measures exhaust gas temperature using our sensor.
Key Features:
Exhaust Gas Type K |
All our AiM thermocouples are 2 pin K type sensors and fit car, bike and kart installations. The 1.5m patch lead is used to connect am AiM thermocouple such as EGT (exhaust gas temperature) or a CHT (cylinder head temperature) to an AiM TC Hub or directly to a Mychron4 or Mychron5 lap timer / dash logger.
Please Note: To use the sensors with an Aim Mychron expansion or EVO4 and EVO4S data loggers you will need a 712-DIN 4 pin patch lead or to use them with an AIM TC Hub or directly to a MyChron4 or MyChron5 kart lap timer / dash logger you will need a 712-DIN 3 pin patch lead. |
AiM are committed to supplying, professional engineers quality Motorsport products. Out cables and accessories are well-engineered and designed for demanding Motorsport applications and the demands that racing puts on components and our products are the best on the market today. |
AiM Exhaust Gas K Type Thermocouple Temperature Sensor M5
- Temperature working range: 0-1000°C (32-1832°F)
- Cable Length: 250mm (9.8")
- Cable Type: Compensated
The drawing below shows the thermocouple in dimensions in mm.
The thermocouple ends with a male Mignon connector. The image below shows the connector pinout and connection table.
- Exhaust Gas Sensor
- 1.5m Patch Lead
