AiM Solo 2 DL LCD World SSP300 FIM Kit
£520.00
The SuperSport 300 World Championship is a motorcycle racing competition on paved surfaces, for production - based motorcycles.
Key Features:
Please Note: If you are unsure this cable will fit your Bike don't hesitate to contact our team. Either by email, phone or our online chat. | |
AiM Solo 2 DL raises the bar for GPS lap timers. It can be connected to your bikes ECU in order to obtain various data from the sensors fitted on your bike. The GPS technology used receives data from three satellite constellations, GPS, Glonass and Galileo, making a vast improvement in data and position precision. Meaning your start time is reduced to a matter of seconds and your lap times are accurate. The Solo 2 DL is already pre-loaded with a data base of over 4,000 tracks from around the world, and is constantly growing. As soon as the Solo 2 DL is switched on it identifies its position and loads the starting line coordinates ready to begin recording lap times. If the track your at isn't on the data base, the Solo 2 DL will automatically enter a auto-learning mode and begin to build the track layout based on your bikes position and record lap times.
The Solo 2 DL provides better reliability from the predictive lap timing function so you can see, in real time, how your current lap compares to your best lap. The LEDs are also configurable to give you a visual indication on whether you are quicker or slower.
Wi-Fi Communication with the PC |
With wifi connectivity you can transfer your data securely and quickly to your laptop or computer without cables. |
Make it even better and add a camera to your kit
Unlock your potential |
Solo 2DL
- Display: Graphical
- Display Resolution: 238 x 99 pixels
- Back Light: 7 configurable RGB colours
- Shift Lights / Alarm LEDs: 10 configurable RGB LEDs
- Integrated Track Database: Yes
- Internal Platform: Internal 3 axis ±5G accelerometer + 3 axis gyro + 3 axis magnetometer
- Wi-Fi Connection: Yes
- GPS: 10 Hz external power: 12V
- Memory: 4 GB
- Battery Type: Rechargeable Lithium
- Dimensions: 98.0 x 73.7 x 30.2mm
- Weight: 240g, battery included
- ECU Connection: CAN, RS232 or K-Line
- Multiple Configuration Management: Yes
- Solo 2DL
- Connection Cable for World SSP 300 Bike
