The Aim Formula Wheel 3 and EVO4s Powerboat Data Logger Racing Kit has been specifically designed for powerboat racing applications and features a small, fully configurable graphical display, showing the data sampled from the EVO4S with a precise and clear display.
"Perfect for Powerboat Racing"
Connection Examples
A flexible display for you data and alerts
The new Formula Steering Wheel 3 features a small, fully configurable graphical display, showing the data sampled by EVO4S or EVO5 with a precise and clear graphics.
You can keep constantly under control lap times and all values coming from the ECU, from the accelerometers and from the GPS (included in EVO4S/EVO5 kits).
Up to 9 pages showing the data you want, as you want it
You can swap among pages showing lap times and data in a 100% customisable way just choose your data and create your pages displaying up to 4 fields each. The “RPM and Lap Time” page layout is also available to display RPM Graph, Lap Time and two channels of your choice.
Lap times
You can see the rolling time, static or predictive lap times
(as an absolute value or as a difference vs. the Best Lap).
Individually configurable LED’s
Six RGB shift lights can be configured for each gear, choosing LED colour and RPM threshold values which will turn it on/off.
Alarms are managed in a very flexible way so you can choose the event that generates the alarm, the LED behaviour (blinking frequency and colour) when the alarm appears and the conditions for its switch-off. A warning message can also be shown.
Highlight your performance
A data summary can be recalled at the end of each session showing the four fastest laps, total running time and total run distance, together with max. RPM and speed values.
You can also see a list of all the laps of the session, with their times and min/max speed.
Technical Specifications
Dimensions: 270x183x48.2 mm (270x183x67 mm with paddle shifts)
Alarms/Functions: 6 shift light led's, 4 configurable alarm led's, 4 remotable functions
Chassis: Anodised aluminium
Finishing : Hand-sewn shammy leather
- Powerboat Formula steering wheel 3,
- CAN cable for logger/ECU Bridge connection
- Free cables.
