AiM Formula Steering Wheel 3
The formula Steering Wheel 3 Powerboat steering wheel is perfect for powerboats offering a clear and precise configuration on the display, also shows data from the EVO5.
Key Features:
You can keep constantly under control your lap times and values coming from the ECU, from the accelerometers and from the GPS (included in the EVO5 kits). |
The AiM Formula powerboat Steering Wheel 3 has six RGB shift lights which can be configured for each gear, choosing LED colour and RPM threshold values which will turn it on/off. Alarm LEDs are managed in a very flexible way. You can choose the event that generates the alarm, the LED behaviour (blinking frequency and colour) when the alarm appears and the conditions for its switch-ff. A warning message can also be shown. |
You can swap among pages showing lap times and data in a 100% customisable way, you can also just choose your data and create your pages displaying up to 4 fields each. The RPM & Lap time page also displays the RPM graph, Lap time and two channels of your choice. |
You can visualise the rolling time, or static lap time, as an absolute value or as a difference vs the best lap. |
Highlight Your Performance
A key data summary is available at the end of each session. The three best laps of the session with their times, min/max speed and min/max RPM. See image below: |
Switch Buttons for External FunctionsWith built in WIFI connectivity, you can easily transfer your data securely and quickly to your laptop or computer without cables. |
Unlock your potential |
Our mission is to help enable you to get the most out of your AiM data equipment… whether you are new to racing or a seasoned professional, there is always something new to learn. |
AiM Formula Powerboat Steering Wheel 3
- Alarms / Functions: 6 shift light LEDs, 4 Configurable Alarm LEDs, 4 removable functions
- Chassis: Anodised Aluminium
- Finishing: Hand Sewn shammy leather
- Dimensions: 270x183x48.2mm (270x183x67mm with paddle shifts
MPN: X07VOLFORM3, 5056421101241
AiM Formula Car Steering Wheel 3
- Formula Steering Wheel 3
