AiM GPS08 Module
AiM GPS08 Module is a precise position sensor. The GPS08 Module is connected via a CAN cable and is simple and quick to install in a number of locations due to being light weight and water proof.
Key Features:
The SmartyCam GPS Module has been designed specifically for the SmartyCam HD 2.1 cameras, and has a 4 pin connection. AiM GPS08 Module is more precise than most existing GPS systems.
What are the benefits ?
Satellite signal is locked rapidly. A few seconds after you switch it on the GPS08 Module is ready to go. There's no risk of missing the signal, with noise or interference on the system, as the other system will guarantee the signal continuity. |
GPS technology represents a true revolution in racing data acquisition. Thanks to GPS08 Module and Race Studio 3 software, as soon as you start your track session you can immediately sample lap and split times as well as speed, position and acceleration.
GPS08 samples ten times per second position, speed and lateral / in line acceleration at any point of the track. Thanks to GPS08 even the predictive lap time will be much more reliable during your race and you will know your time gap vs your best lap with absolute precision. |
The GPS08 Module is available in 0.5m, 1.3m, 2m, 4m cable lengths. Or a 2m, 4m cable Roof Version ( with cable entry from underneath) specifically designed for easy installation on covered cars. The Roof Version works well when fitted to race bike fairings, as the module can be bolted through the fairing with the advantage being that the cable can be detached at the GPS Module making removal much quicker and more convenient. |
AiM SmartyCam HD 2.1 Only GPS Module
- Dimensions: 64.8 x x53.2 x 19.7mm
- Weight: 60.5 g
GPS08 Module Roof Version
- Dimensions: 64.8 x 56.8 x 21.4mm
- Weight: 100g
