Aim GPS08 Motorcycle Fairing Mount GPS Module for Smartycam HD – Aim Shop - Motorsport Data Loggers, Displays and Laptimers
SKU: SM-EX-AN-CR2-B
Availability: 44 in stock
£312.00
QTY:
Trust Badge
Aim GPS08 Motorcycle Fairing Mount GPS Module for Smartycam HD. The Aim GPS08 Module GPS Roof Mount Version for Smartycam is a roof mount version of the GPS08. This is used where you need to install the GPS module externally
Aim GPS08 Module GPS Roof Mount Version for Car Racing
Thanks to the Aim GPS08 Module GPS Roof Mount Version for Smartycam and Race Studio 3 software, as soon as you start your track session you can immediately sample lap and split times as well as speed, position and acceleration, all the information needed for engine tuning as well as for improving your driving technique.GPS technology represents a true revolution in motorcycle racing data acquisition.
Aim GPS08 GPS Module for Car Racing
Two satellite systems for top reliability and precision
The Aim GPS08 Car Racing GPS Module is more precise than most of the existing GPS systems, as it has been designed to add to the GPS satellite's signal the Global Navigation Satellite (Glonass) system's signal.
With an average of almost twenty satellites working in conjunction, GPS08 guarantees a precision and a reliability simply not comparable to the old generation GPS systems.
The Benefits are Huge!
  • An average of less than one meter tolerance, which means absolute precision in determining vehicle position in curves and when the finish line is very close to another track segment
  • Satellite signal is locked very rapidly. A few seconds after switch-on, the GPS08 is ready to operate
  • No risk of missing the signal anymore, as - in case of 'noise' or interferences on one system - the other system will guarantee the signal continuity
With your track included in the Aim database, the GPS08 does it all by itself.
The Aim GPS08 Car Racing GPS Module stores the finish line coordinates of hundreds of tracks all over the world. Opening Race Studio 3 you will see the huge list of tracks included in the Aim database, sorted by Nation, circuit and surface type: you will be able to create your own collections, adding/removing tracks as you wish.
Should your home track be missing, after one lap its coordinates will be automatically detected by GPS08 and - once downloaded onto your PC - you will be able to include it in your own tracklist.
So, immediately after switch-on, GPS08 Racing GPS Module will determine its position, identify the track and start loading lap times.
You do not need to configure anything before going to the track: GPS08 car racing module will do it all by itself.
Much More than just Lap Times!
The GPS08 Car Racing GPS Module samples ten times per second position, speed and lateral/in-line acceleration at any point of the track: all the data needed for a precise evaluation of vehicle and driver behavior, which is the necessary step to improve performance.
Thanks to GPS08, even the predictive lap time will be much more reliable: in any moment of your race, you will know your time gap vs. your best lap with absolute precision.
GPS08 samples ten times per second
Features
  • GPS08 Motorcycle racing module guarantees a precision using an average of almost twenty satellites
  • You do not need to configure anything before going to the track: GPS08 will do it all by itself.
Technical specs
GPS08 Module
Dimensions: 64.8 x 53.2 x 19.7 mm
Weight: 60.5 g
GPS08 Module Roof version
Dimensions: 64.8 x 56.8 x 21.4 mm
Weight: 100 g
Video
N/A
In The Box
Parts and Accessories
N/A
Documentation
Motorcycle racing GPS module
