Aim GS-DASH & EVO 4s Truck Racing Data Logger Kit – Aim Shop - Motorsport Data Loggers, Displays and Laptimers
SKU: GS-DASH-EVO4-KIT
Availability: 49 in stock
£1,560.00
QTY:
Trust Badge
The Aim GS-DASH & EVO 4s Truck Racing Data Logger Kit has been designed to show data sampled by the new generation of Aim data logger, the EVO 4S. All data coming from your truck’s ECU, from the accelerometers, from the GPS module as well as from your custom sensors.
Easy and immediate readability
In its compact structure, Aim GS-DASH & EVO 4s Truck Racing Data Logger Kit  features a wide 268x128 pixel display to maximise readability.  The screen can be backlighted in one of the seven available colors and the incorporated light sensor makes brightness and contrast ideal in all light conditions.
In its compact structure, The Aim GS-Dash Display for EVO4s and EVO 5  features a wide 268x128 pixel display to maximise readability
Up to 9 pages showing the data you need
In its compact structure, GS-Dash features a wide 268x128 pixel display to maximise readability.  The screen can be backlighted in one of the seven available colors and the incorporated light sensor makes brightness and contrast ideal in all light conditions.
Aim GS-Dash Car Racing Display data 1
Aim GS-Dash Car Racing Display data 2
Aim GS-Dash Car Racing Display data 3
Lap times
You can see your truck rolling time, static or predictive lap times
(as an absolute value or as a difference vs. the Best Lap).
Aim GS-Dash Car Racing Display data 4
Recall your session highlights
A key-data summary is available at the end of each session where you can also see a list of all the laps of the sessions, with their times, min/max speed and min/max RPM's.
A key-data summary is available at the end of each session: you can also see a list of all the laps of the session
Configure your LED’s One by One
Five RGB shift lights can be configured for each gear, choosing LED color and RPM threshold values which will turn it on/off.
Aim GS Dash Configure your LED
Alarms are managed in a very flexible way: you can choose the situation that generates the alarm, the LED behavior (blinking frequency and color) when the alarm appears and the conditions for its switch-off. A warning message can also be shown.
Aim GS-Dash Car Racing Display shift
Easy Configuration
Configuration of Shift lights, alarms and customized data pages is intuitive and immediate using the dedicated Race Studio 3 software.
Shift Lights and Alarms are to be configured using Race Studio 3 configuration panel (see image on the left).
screenshot 1
Data is viewed in customisable pages. With few clicks you can enable up to eight Custom Pages: you decide where to show the desired variables (up to 4 on each page) from those sampled by the ECU, the accelerometers and the GPS values from EVO4S/EVO5. Configuration can be done either using Race Studio 3 (see panel on the left) or via keyboard (see below).
Compact and resistant chassis
Its small dimension makes it particularly suitable for small cockpit installation (i.e. bikes, formula cars). Manufactured in aluminum with edge-to-edge glass and metallic pushbuttons the GS-Dash is robust and fully waterproof.
"Aim GS-Dash Truck Racing Dash Display - The New Dash  Display from Aim"
