AiM GS Dash & EVO4S Bike Data Logging Kit
£1,995
The Ultimate GS Dash & EVO4S Data Logging Kit
AiM GS Dash & EVO4S data logging kit provides you with all the help to improve your performance on the track or road.
Key Features:
Build your kit your way:
AiM EVO4S Data Logger with GPS08 with 1.3m cable samples all the information you need. Data coming from the ECU via CAN, RS232 or K-Line, from the internal accelerometer and gyro, from the GPS08 Module which permits automatic and precise lap time calculations. The GS Dash is a compact, flexible and fully configurable graphical display, showing data sampled by the EVO4S. A Wide Range of Sources for your DataGS Dash swaps among pages showing lap times and data in a 100% customisable way. You choose the data and create the pages displaying up to 8 fields on each. The RPM and lap time page layout is also available to display RPM Graph, Lap Time and two channels of your choice. |
Many Sensors can be connected to EVO4S via:
Connection Examples
GS Dash
- Display Resolution: 268x x128 pixels
- Ambient light sensor: Yes
- Shift Lights: 5 configurable RGB LEDs
- Display Pages: Fully configurable
- Dimensions: 127.8 x 82 x 22.2mm
- Weight: 380g
AiM EVO4S Bike Data Logging Kit
- LEDs: 1 system status
- CAN Connections: 2
- ECU Compatibility: + 1,000 industry leading ECUs
- Expansion CAN connections: GPS, Channel Expansions, Thermocouple Expansions, Lambda Controllers, SmartyCam HD
- Analog inputs: 5 fully configurable, max 1,000 Hz each
- Digital inputs: 2 speed inputs, lap signal, coil RPM input
- Digital outputs: 1 (1Amp max)
- Accelerometer: Internal Three-axial + 5G + Three-axial Gyroscope
- Internal memory: 4GB
- Body: Anodised aluminium
- Weight: 330g
- Power consumption: 350 mA
AiM EVO4S Bike Data Logger Kit
- EVO4S Data Logger
- 1.3m GPS08 Module
- Bracket
- RPM Output
- Power Supply 12V
- USB
- CAN
GS Dash
- GS Dash with spiral cable
- Installation manual
