Aim Hall Speed Pick up 712 1m – AimShop.com
SKU: S-S-H712
Availability: 43 in stock
£72.00
QTY:
Trust Badge
The Aim Hall Speed Pick up 712 1m is a sensor what varies its output when it meets a magnetic field. The sensor contains three wires and produces a digital signal.
The sensor consists a thin piece of metal what passes a continuous current through it. When the sensor is placed in a magnetic field the electrons move to one side of the metal and protons move to the other side of the plate. Then you will be able to get a voltage. The sensor only produces around seven volts. When the electrons move to one side a potential difference is produced between the two sides of the metal.
M8 Thread
