AiM Hall Speed Sensor
The AiM output varies when it meets a magnetic field.
Key Features:
AiM 712 Hall Speed Pick Up Sensor (1m cable). The output varies when it meets a magnetic field. The three wire sensor produces a digital signal. |
The sensor consists of a thin piece of metal that passes a continuous current through it. When the sensor is placed in a magnetic field the electrons move to one side of the metal and protons move to the other side of the plate. You will then be able to get a voltage. |
The sensor only produces around Severn volts. When the electrons move to one side a potential difference id produced between the two sides of metal. |
AiM Hall Speed Pick up 712 1m Cable
