Aim Inertial Measurement Unit IMU – AimShop.com
SKU: IMU
Availability: 30 in stock
£150.00
QTY:
Trust Badge
The Aim Technologies Inertial Measurement Unit (IMU) measures acceleration and angular rate for all three orthogonal axes at a sampling frequency of 200Hz and outputs the data via CAN.
SENSOR SPECIFICATIONS
Acceleration Measurement Range: ±2g / ±4g / ±8g (default) / ±16g
Angular Rate Measurement Range ±245dps (default) / ±500dps / ±2000dps
Acceleration Accuracy< 1% FS
Angular Rate Accuracy < 1.5% FS
Package Temperature Range -20˚C to 85˚C
Sampling Frequency 200Hz
Low-Pass Cutoff Frequency 80Hz
ELECTRICAL SPECIFICATIONS
Supply Voltage, Vs:  5 to 8 V
Supply Current, Is (typ) 25 mA
Features
Reverse polarity protection
Over-temperature protection (125˚C)
MECHANICAL SPECIFICATIONS
Weight:  < 5 g
L x W x H (max) 36 x 18 x 3.5 mm
Protection Rating: IP64
