SAME-DAY DISPATCH
on orders before 3pm
FINANCE AVAILABLE
on selected products
FIRST-CLASS SUPPORT
Aim IR Pick Up 712 Plug 300cm
£70
Aim IR Pick Up 712 Plug 300cm. IR Sensors work by using a specific light sensor to detect a select light wavelength in the Infra-Red (IR) spectrum. By using an...
Aim IR Pick Up 712 Plug 300cm. IR Sensors work by using a specific light sensor to detect a select light wavelength in the Infra-Red (IR) spectrum. By using an LED which produces light at the same wavelength as what the sensor is looking for, you can look at the intensity of the received light.
When an object is close to the sensor, the light from the LED bounces off the object and into the light sensor. This results in a large jump in the intensity,
