AiM Kart Brake Pedal Position Sensor Linear Travel Pot 10mm
£85
Brake Pedal Position Sensor The AiM linear short stroke (10mm) displacement potentiometer for measuring brake pedal movement. Key...
Key Features:
  • Brake position sensor
  • 4 pin
  • 10mm displacement
  • Free race studio 3 download
The linear short stroke (10mm) displacement potentiometer is ideal for measuring brake pedal movement. A pedal travel sensor such as this can be simpler to install in many vehicles than plumbing a pressure sensor in the brake line.
The compact sensor body measures just 3/4" (19) OD X 1 3/8" (35mm) long overall (less plunger). Two 1/4" (6mm) mounting holes are located 1.34" (34mm) centre to centre
Ideal for high precision data acquisition or control systems.
      User Guide
      Technical sheet
