Aim LCU ONE CAN Lambda Controller + Analogue Interface Kit For Motorcycle
£330
The LCU ONE Controller Unit with Analogue Interface Kit , allows you to perfectly tune the carburetion of...
The LCU ONE Controller Unit with Analogue Interface Kit , allows you to perfectly tune the carburetion of your engine, appreciably improving your bike performance.
It fits petrol engines as well as alcohol based fuel engines. It is intended to check lambda probe is properly working as well as to transmit Air/Fuel Ratio values or Lambda values both through the CAN bus or through a serial RS232 bus
All LCU-One lambda controllers use a wide band Bosch LSU 4.9 probe either for its capacity of saving the original calibration for its all life and for its duration: Bosch LSU 4.9 probe, in fact, has been designed to last for more than 100.000 km on a stock car.
The LCU ONE Controller Unit - Analogue Interface for Motorcycles can detect punctual Lambda value from 0.65 to 1.6, offering you an extremely precise measurement, very useful for engine tuning.
Through the analysis of the remaining oxygen, LCU-One points out possible oxygen excess/lack in the carburetion, providing an essential information for 4 strokes engines: configurability of Stoichiometric ratio allows LCU-One to be used on petrol powered engines as well as on diesel or on alternative fuel (bio fuel, ethanol) powered ones.
Aim LCU ONE Controller Unit - Analogue
Interface for Cars range is available in three different versions:
  • LCU-One CAN: uses a CAN bus and is extremely easy to install.
  • LCU-One Analogue: uses a serial line for programming and an analogue output proportional to lambda value. To be even more user-friendly, these two versions of LCU-One switch on/off together with the logger.
  • LCU-One CAN + Analog is equipped with both CAN bus and analogue output.
LCU-One CAN
  • CAN connection
The product configures Stoichiometric point and provides:
  • Lambda value and Air/Fuel ratio
  • Lambda probe temperature and diagnosis
LCU-One Analog
The product provides Lambda value and Air/Fuel ratio and - thanks to the dedicated Lambda Configurator software, LCU-One Analogue allows to configure:
  • Stoichiometric point
  • Analogue output (0-5 Volt)
The product configures:
  • CAN connection+ Analogue output
LCU-One CAN + Analogue also provides:
LCU ONE Controller Unit - Analogue Interface for Cars technical specs
Dimensions: 80x37x15 mm
Waterproof: IP67
In The Box
Aim LCU One Lamda Controller in the box
