AiM Lotus MX2E SmartyCam HD Track Day Camera
The AiM Lotus SmartyCam HD Rev 2.1 Motorsport Video Logger Camera is ideal for car interior installation, where a narrower field of vision (FOV) is needed.
Key Features:
Real Time Overlay
High Storage Capacity
AiM Lotus MX2E SmartyCam HD 67° Track Day Camera
- Video Format: H.264 1280 X 720 pixels @ 30 fps
- Display Resolution: 128 X 128 pixels
- Lens: Telecentric with 6 elements
- Field of View: 67°, 84°
- Internal Battery: Rechargeable Lithium Battery - 1,950mAh
- Battery Charge: 700 mAh 12V
- Internal Battery Duration: 120 - 150 of recording
- External Power: 9 - 15 V
- Supported SD Card: Up to 128 GB
- Memory Capability: 1.5 GB ( 1 hour low quality recording)
- 2 GB ( 1 hour medium quality recording)
- 4 GB. ( 1 hour high quality recording)
- Accelerometer: Three-axial + 5G
- Usage Temperatures: _10°C / +60°C
- Auto Power ON: Yes if connected to the AiM logger
- Auto Power OFF: Yes
- Body: Anodized Aluminium
- Dimensions: 87 x 63 x 49mm
- Bullet Cable Length: 2.0m
- Weight: 280g battery included
- SmartyCam HD Rev 2.1
- Dash or Logger Connection Cable
- Battery charger
- USB/AC power adaptor
