AiM M10 VDP Pressure Sensor.
AiM sensor fits the measurement of pressure of liquids such as oil and fuel.
Key Features:
VDO Pressure Sensor |
The 0-10 bar sensor is made of a cylinder with M10*1 thread, that has to be screwed to the engine. The two connectors that sample GND and pressure signals. |
Do not use it to measure brake pressure. |
AiM Technologies are committed to supplying, professional engineers quality Motorsport products. Our cables and accessories are well-engineered and designed for demanding Motorsport applications and the demands that racing puts on components. Which makes ours amongst the best in the market place today. |
Unlock your potential |
Aim M10 VDO Pressure Sensor 0-10 Bar
AiM M10 VDO Pressure Sensor 0-10 Bar
