SAME-DAY DISPATCH
on orders before 3pm
FINANCE AVAILABLE
on selected products
FIRST-CLASS SUPPORT
Aim M12 Hall Speed Pickup 719
£60
Aim M12 Hall Speed Pickup 719 Car.  A Hall effect sensor is a sensor what varies its output when it meets a magnetic field. The sensor contains three wires and produces...
Aim M12 Hall Speed Pickup 719 Car.  A Hall effect sensor is a sensor what varies its output when it meets a magnetic field. The sensor contains three wires and produces a digital signal. The sensor consists a thin piece of metal what passes a continuous current through it.
When the sensor is placed in a magnetic field the electrons move to one side of the metal and protons move to the other side of the plate. Then you will be able to get a voltage. The sensor only produces around seven volts. When the electrons move to one side a potential difference is produced between the two sides of the metal.
