Water Temperature Sensor with Patch Lead.
AiM M5 water temperature sensor with patch lead.
Key Features:
The thermo resistor must be placed in the cooling system/oil sump. It is recommended to install the sensor far from heat and electromagnetic interference sources such as the RPM cable or lap receiver cables. |
The M5 sensor also comes with a 712 - 719 3 pin patch lead. |
AiM Technologies are committed to supplying, professional engineers quality Motorsport products. Our cables and accessories are well-engineered and designed for demanding Motorsport applications and the demands that racing puts on components. Which makes ours amongst the best in the market place today. |
Unlock your potential |
AiM M5 Water Temperature Sensor for Mychron 4 & 5 with 1.5m 712 - 719 3 Pin Patch Lead.
- The sensor ends with a 4 pin male 719 binder connector
- Temperature working range: 0/150°C
- Patch lead Length: 1.5m
AiM M5 Water Temperature Sensor for Mychron 4 & 5 with 1.5m 712 - 719 3 pin patch lead.
