AiM M5 Water Temperature Sensor for Mychron 4 & 5 with 1.5m Patch Lead
£100
Water Temperature Sensor with Patch Lead. AiM M5 water temperature sensor with patch lead. Key Features: M5 water...
Key Features:
  • M5 water temp sensor
  • 1.5m Patch lead
  • Free race studio 3 download
This AiM device can measure and sample water temperature using a sensor (thermo resistor) placed in the cooling system. (Gearbox).
The thermo resistor must be placed in the cooling system/oil sump.
It is recommended to install the sensor far from heat and electromagnetic interference sources such as the RPM cable or lap receiver cables.
The M5 sensor also comes with a patch lead with a metallic male binder 3 pin and a plastic female binder connector 4 pin.
AiM Product Video
    • The sensor ends with a 4 pin male 719 binder connector
    • Temperature working range: 0/150°C
    • Patch lead Length: 1.5m
