AiM Memory Module SD Card Data Logger Storage
£150.00
AiM Memory Module
The AiM Memory Module is a small SD card holder that can be connected via CAN bus to the MXL2, MXG, MXP, MXS.
Key Features:
  •  Data storage
  • LED recording indicator
  • 5 pin 712 male binder
  • Free race studio 3 download
The AiM Memory Module is a small SD card holder that can be connected via CAN bus to the MXL2, MXS, MXP, MXG dashes, also the suitable for the EVO4S and EVO5 data loggers.
Connect the module to your logger and the data will be saved both in the logger and on the SD card with no configuration needed.
The SD card can be removed and replaced during pit stops, while the car engine is still on. This makes it easy to get the data during races or long tests, when time is limited.
When the session is over, just remove the SD card from the Module and put it into your PC and download the data using Race Studio 3.
AiM Technologies are committed to supplying, professional engineers quality Motorsport products. Our cables and accessories are well-engineered and designed for demanding Motorsport applications and the demands that racing puts on components. Which makes ours amongst the best in the market place today.
Unlock your potential
    • Max power consumption: 50 mA
    • Cable length: 40cm
    • SD Card: 4GB it supports up to 32 GB
    • Dimensions: 55.5 x 78.3 x 18mm
    • Weight: 103g
