AiM Motocross Suzuki RMZ 250CC & 450CC Solo 2 DL Plug & Play Lead
£50
Suzuki RMZ Solo 2 DL Plug & Play Cable. The Suzuki ECU Interface cable is a specific cable...
The Suzuki ECU Interface cable is a specific cable which allows easy installation and connecting to an AiM Solo 2 DL lap timer.
Key Features:
  • Plug & Play interface cable
  • Simple Wiring
  • Receive Data
  • Free Race Studio 3 Download
Suzuki Solo 2 DL Plug & Play Cable Available For:
  • Suzuki RMZ 4-stroke 250cc from 2010-2013
  • Suzuki RMZ 4-stroke 450cc from 2008-2013
Examples of Protocols Below
RPM, Throttle position sensor voltage, Throttle position sensor, Engine coolant temperature, Intake air temperature, Manifold air pressure, Battery supply, Speed, Ignition angle, Injection time.
Please Note: Not all data channels outlined in the ECU are validated for each manufacturer model or variant, some of the outlined channels are model and year specific, and therefore may not be applicable.
Not Enough Check Out Our Solo 2 DL & SmartyCams
AiM Solo 2 DL Product Video
    AiM Suzuki RMZ 250CC & 450CC Plug & Play Lead
    • AiM Suzuki RMZ 250CC & 450CC Plug & Play Lead
