AiM Brake Pressure Sensor.
AiM M10 brake pressure sensor with 719 binder connector.
Key Features:
This sensor is classed as an analog sensor and will use one analog input on the logger or display which can be used not only to see brake pressure, but also allows you to see braking points both start and end. |
You can also see if the driver is getting tired while braking during a race or the brake system id becoming in-effective. Running this in conjunction with a throttle sensor also allows you to see costing time, the most important thing to reduce, to gain more lap time. |
AiM Pressure Sensor 0-10 bar
- Supply: 8-16V
- Accuracy: <+/-0.5% FS (CLNH - combined non-linearity and hysteresis)
- Characterisation: 500 mV / 0 bar - 4500 mV / 10 bar
- Temperature working Range: < 10mA
- Sealing: IP66
- Weight: 30g
- Cable length: 400mm
- Thread: M10 - 3/8 24 - 1/8 NPT
