Same-day dispatch
on orders before 3pm
Finance available
on selected products
First-class support
Aim Motorcycle Data Hub 4x CAN Connection Multiplier
£50
Product code: X08HUB010 The Aim Motorcycle Data Hub 4x CAN Connection Multiplier used for the acquisition of all essential data you need to evaluate your car performance needs the connection of many...
The Aim Motorcycle Data Hub 4x CAN Connection Multiplier used for the acquisition of all essential data you need to evaluate your car performance needs the connection of many peripherals to your data logger. This implies the presence of a great number of cables.
To solve this problem, Aim developed Data Hub, the new CAN connection multiplier that works as an interface between all Aim loggers and their peripheral equipments.
Each Hub connects the logger with four peripherals: i.e. LCU lambda controller, GPS08 Module and one or more TC Hub (thermocouple multiplier).
The Data Hub takes all the information you need to your logger with only one cable, minimising wires overall.
Data Hub is available in two versions:
Data Hub CAN connection multiplier 40 cm cable - X08HUB010
Data Hub CAN connection multiplier 150 cm cable - X08HUB150
Two way Data Hub
Dimensions: 70x30x23,5 mm
CAN cable length: 40 cm
Source cable length: 165 cm
Weight: 86 g
Waterproof: IP65
Four way Data Hub
Dimensions: 123x30x23,5 mm
CAN cable length: 40/150 cm
Weight: 97 g
Waterproof: IP65
