FREE Shipping NEXT DAY Delivery Call +44 (0)1782 393843 Shop now, pay later
AiM Motorcycle Hall Speed Pick up 712 1m
£60.00
AiM Hall Speed Sensor
The AiM output varies when it meets a magnetic field.
Key Features:
  • Speed sensor
  • 4 pin binder 712
  • Free race studio 3 download
Magnetic Speed Sensor
AiM 712 Hall Speed Pick Up Sensor (1m cable). The output varies when it meets a magnetic field. The three wire sensor produces a digital signal.
The sensor only produces around Severn volts. When the electrons move to one side a potential difference id produced between the two sides of metal.
    AiM Hall Speed Pick up 712 1m Cable
