Product code: X08RTN010
Aim Motorcycle Remote Buttons Interface for MXL2,MXG,MXS
The remote buttons interface has been designed to make MXL2/MXG/MXS use easier when the system buttons can be difficult to push: typically, when the dashboard where the system is installed is too narrow or too far from your reach.
Basically, it offers 6 contacts to connect to 6 different push buttons.
The first four are configured in order to simulate the systems buttons, the fifth is intended to turn ON/OFF the back light and the sixth for resetting the second odometer.
The interface has been designed in order to accept a configuration for changing functionality, in case dedicated features will be required.
