AiM Water / Oil Thermoresistor 1/8th NPT Thread
Our water / oil thermo resistor sensor can measure and sample temperature .
Key Features:
Measure Water / Oil Temperature |
The thermo resistor should be placed in the pipe that goes from the radiator to the cylinder. Install the sensor away from heat and electromagnetic interference sources, such as RPM cable or lap timer receiver cables.
Please Note: MXG / MXS / MXL (Strada and Pista) / MXL2 / EVO5 / MXm etc harnesses are fitted with 719 connections. To extend the length between your dash display / logger and the analogue sensor, please use the 719-719 extension lead which is available in various lengths from 0.5 - 3 metres. For most installations you will need one of these leads. EVO4 / EVO4S logger / Channel Expansion are fitted with 712 connections and require a 712-719 extension lead to connect these sensors. |
AiM are committed to supplying, professional engineers quality Motorsport products. Our cables and accessories are well-engineered and designed for demanding Motorsport applications and the demands that racing puts on components and our products are the best on the market today. |
AiM Water / Oil Thermal Resistor 1/8th NPT Thread
- Temperature Range: 0/150°C
- Cable Sensor Length: 25cm
The image below shows the thermo resistor dimensions in mm.
The thermo resistor ends with a 4 pin Binder 719 male connector. The image below shows the connector pinout from termination side. Resistor is mounted between 1 and pin 4.
