AiM MXG 1.2 7" TFT Car Dash Display Logger
£1,900
AiM MXG 1.2 Dash Logger. Check your vehicle  compatibility Manufacturer ECU Aftermarket ECU If you are unable to...
Manufacturer ECU
Aftermarket ECU
If you are unable to locate your vehicle don’t worry our AiM products are capable of fitting all ECU’s.
Please contact us via chat service below or by email: sales@aimshop.com
The MXG 1.2 Dash Logger has a 7" TFT display, and can acquire and display data coming from your ECU.
Key Features:
  • 7" TFT high contrast display
  • 3-axis accelerometer & gyroscope
  • Real time fully configurable math channels
  • GPS08 Module
  • CAN output
  • 8 configurable RGB LEDs
  • Two digital outputs
  • Integrated shift array
  • Wi-Fi connectivity
  • Free race studio 3 download
The AiM MXG 1.2 Dash Logger has an extra wide 7" high contrast display which is fully configurable by the user and is suitable for many different motorsports categories. The MXG has been designed to acquire and display data coming from your ECU, the internal accelerometer and gyro, the GPS08 Module analogue/digital inputs and predefined math channels.
Your performance and data acquired can also be incremented by adding up to eight expansion modules.
 The main difference between this MXG and the MXS, MXP dash loggers are the size.
Connecting the MXG 1.2 dash to your ECU ( standard vehicle or racing ECU) is very simple. You can sample and display dozens of channels straight from your vehicles ECU. This is normally the quickest set up. Needing only a cable connection to the ECU instead of multiple connections to analogue sensors.
Your sampled data depends on the actual ECU but typically RPM, engine load, throttle position, (TPS), oil, air, water temperature, oil pressure, battery voltage, speed, gear, lambda value (air/fuel ratio). The list of available ECU drivers is constantly updated and upgraded and includes approximately 1,000+ ECUs. Either stock or racing.
Configurable Pages
You can define all the custom pages you want, choosing from a wide library of page styles, defining which data to be shown, their end scale and measure units. Swapping between pages can be managed pushing one or two push buttons.
Flexible Alarms
There are eight configurable RGB alarm LEDs. You can choose the conditions & colours. You can select a solid alarm or a flashing one and the flashing frequency, you can even choose to have a accompanying text message and set the alarm priorities.
For integrated shift lights you can choose from a host of advanced multi-coloured RGB shift light patterns that can be customised to how you want, and for each unique gear when required.
GPS08 Module (included in your kit)
The GPS08 Module connected via CAN to the MXG makes lap time calculation and track position analysis very easy. Each MXG memory stores more than 4,000+ tracks start and finish line coordinates.
If the tracks is not on the data base its no problem, you can add the start & finish coordinates to the MXG via your PC before you go to the track using our Race Studio 3 software.
Choose which cable length you want.
CAN Output
With the CAN Output you can send messages directly to an existing CAN network in order to improve the range of vehicle control possibilities.
Two Digital Outputs
MXG 1.2 features two digital outputs. The two digital outputs (Dout) are LOW SIDE type (switch to ground) they can be configured in order to be turned on/off depending on the value of the analog or digital inputs.
They permit to automatically run external systems, i.e. to switch on/off additional lights, to activate/de-activate a cooling fan or circulation pumps, etc, when a certain event happens.
Integrated Shift Light
With the MXG you can choose from a host of advanced multicoloured RGB shift light patterns that can be customised as want them to be, also for each unique gear when required.
Turn Your Dash/Logger Into A Rearview Mirror
The MX Series is now available to manage up to two rear cameras.
MXG Connection Example
Below is an example of items that can be added to our MXG for incrementing the performance and the data.
Pin Harness
Compare AiM Dashes
AiM Product Video
MXG 1.2 7" TFT Dash Logger
  • Display: 7" TFT
  • Resolution: 800x480 pixels
  • Contrast: 1,000:1
  • Brightness: 700cd/m2-1,100 Lumen
  • Ambient Light Sensor: Yes
  • Alarm LEDs: 8 RGB freely configurable
  • Shift Lights: 10 integrated freely configurable RGB LEDs
  • CAN Connections: 3
  • ECU Connections: CAN RS232, K-Line
  • ECU Compatibility: 1,000 industry leading ECUs
  • Expansion CAN Connections: GPS, Channel Expansion, Thermocouple Expansions, Lambda Controller, Smartycam HD
  • Analog inputs: 8 fully configurable, max 1,000 Hz each
  • Digital inputs: 4 speed inputs, lap signal, coil RPM input
  • Digital outputs: 2 (1 A max each)
  • Second CAN: Yes
  • Wi-Fi Connection: Yes
  • Accelerometer: Internal Three-axial + 5G + Three-axial Gyroscope + 3 axis magnetometer
  • Internal memory: 4 GB
  • Body: Anodised Aluminium
  • Pushbuttons: Metallic
  • Connectors: 2 Motorsport connectors + 1 Binder connector
  • Power consumption: 400mA
  • Dimensions: 237x127x26mm
  • Weight: 950g
Search compatible ECU's by manufacturer supported by AiM
Click here >
AiM MXG Car Racing Dash Logger
AiM MXG 1.2 7" TFT Dash Logger
  • MXG 1.2
  • 37 pin standard harness
  • GPS08 Module with cable
  • USB cable
  • Software installation CD
