AiM MXG 1.2 Strada Standard Icons Dash Display
£950
AiM MXG Strada Standard Icons Dash Display Check your vehicle  compatibility Manufacturer ECU Aftermarket ECU If you are...
Manufacturer ECU
Aftermarket ECU
If you are unable to locate your vehicle don’t worry our AiM products are capable of fitting all ECU’s.
Please contact us via chat service below or by email: sales@aimshop.com
AiM 7" MXG 1.2 Strada Display with Standard Icons
The MXG Strada Dash features a 7" wide colour TFT display with great visual impact.
Key Features:
  • 7" TFT display
  • 1000 + ECU connections
  • Ambient Light Sensor
  • 10 multi-coloured RGB shift lights
  • 8 analogue inputs
  • 6 digital inputs
  • Second CAN
  • Two digital outputs
  • Configurable pages
  • Free race studio 3 download
Aim MXG Strada with Standard Icons
The AiM MXG 1.2 Strada Dash is a 7" colour display which offers a great visual impact. It is configurable to show all the information coming from the Engine Control Unit (ECU), analogue  / digital inputs, pre-defined math channels and the optional GPS Module.
Connecting the MXG 1.2 Strada Dash to your ECU (road or race) is very simple. You can sample and display dozens of channels straight from your vehicles ECU. This is often the quickest and easiest setup, needing only two cable connections to the ECU instead of multiple connections to analogue sensors.
The sampled data depends on the actual ECU but typically RPM, throttle position (TPS), oil / air / water temperature, oil pressure, battery voltage, speed, gear, lambda value (air / fuel ratio). The list of ECU drivers is over 1000+ and is constantly being updated and upgraded.
Pre-Configured Pages
The MXG Strada shows together with RPM scale, all the data you need such as speed, water temperature and oil pressure, lap times and much more. You can choose the custom pages you want, including up to four additional fields. We have a large library of page styles, defining which data to be shown and their end of scale and measure units, also swapping between pages is easy using the push buttons.
Flexible Shift Lights & Alarms
The MXG has 10 multi-coloured RGB shift lights can be customised to how you like them. Defining the RPM threshold for each single gear. The same flexibility applies to the configurable RGB alarm LEDs. You can configure them in order to turn them on/off depending on analogue or digital inputs.ECU values, expansion values, math channels or optionally a GPS08.
You choose the conditions and colours, you can select a solid alarm or a flashing one, also the flashing frequency. It is also possible to configure an accompanying text message on the display and set the alarm priorities.
High Contrast TFT Display
The MXG Strada has a 7" high contrast TFT display. It's visual quality is optimised by it's ambient light sensor which keeps the backlight at the best brightness levels, avoiding the screen from dazzling you when it gets dark, yet keeping it bright and visual during the day.
Flexible Shift Lights and Alarms
The MXG 1.2 Strada has 10 multi-coloured RGB shift lights which can be customised to your liking to define the RPM threshold for each single gear. The same flexibility applies to the configurable RGB alarm LEDs. You can configure them in order to turn them on / off depending on analogue or digital inputs, ECU values, expansion values, math channels or optionally GPS information.
You can choose the conditions, colours. You can select a solid alarm or a flashing one, also the flashing frequency. You can also configure an accompanying text message, and set the alarm priorities.
Two Digital Outputs
The MXG Strada has two digital outputs. These LOW SIDE type (switch to ground), can be configured in order to be activated/deactivated depending on the value of the analogue/digital outputs. This allows you to automatically run external systems, such as switch on/off additional lights or to activate/de-activate a cooling fan or circulation pumps etc when a certain event happens.
MXG 1.2 Strada Connection Example
Below is an example of items that can be added to our MXP Strada for incrementing the performance and the data.
Turn Your Dash/Logger Into A Rearview Mirror
The MX Series is now available to manage up to two rear cameras.
Compare AiM Dashes
AiM Product Video
  •  Display: 7' Display
  • Resolution: 800x480 pixels
  • Brightness: 1000:1
  • Ambient light sensor: Yes
  • Shift lights: 10 configurable RGB LEDs
  • CAN connections: 2
  • ECU connections: CAN, RS232 or K-Line
  • ECU compatibility: +1000 industry leading ECUs
  • Expansion CAN connection: GPS, Channel Expansion, TC Hub, Lambda Controller, SmartyCam HD
  • Analog inputs: 8 fully configurable, max 1000 Hz each
  • Digital inputs: 1 speed input, coil RPM input
  • Digital outputs: 1 (1Amax)
  • Second CAN: Yes
  • Body: Anodised Aluminium
  • Pushbuttons: Metallic
  • Connectors: 2 AMP connectors + 1 Binder connector
  • Power consumption: 400 mA
  • Dimensions: 237x127.6x26mm
  • Weight: 950g
ECU Connections & Support
Search compatible ECU's by manufacturer supported by AiM
Click here >
AiM MXG 360° View
  • MXG Strada
  • 14 pins standard cable
  • 23 pin connector + contacts
  • Software installation CD
