AiM MXG IVA Compliant 7" Plug and Play Dash Kit
£1,029
The Road Legal - MOT Approved, MXG IVA Compliant 7" Plug and Play Dash Kit, is a complete...
The Road Legal - MOT Approved, MXG IVA Compliant 7" Plug and Play Dash Kit, is a complete Road-Legal Display Solution for OEM, Kit Car Builders and Race Car Builders.
The kit has pre-configured, simple wiring connections, for all the relevant electrical items of your vehicle such as Indicators, Lights, Fuel Gauge, Hazard Lights, Handbrake Warning etc
Perfect Dash & Wiring Kit for any Car!
The key to the system, is the specially designed wiring loom included in the kit, that makes it a ‘Plug & Play’ easy installation of your vehicle electrics. This is all connected to your vehicle’s Engine ECU, to allow easily configurable warning lights and gauges as well as Speed / Gears Revs etc.
The Kit Includes:
  • Road Legal IVA Compliant 5” TFT Colour Display Dash
  • ECU Connection Lead
  • Simple Connection Harness
  • Wheel Speed Sensor,
  • All Software needed
MXS Strada Analog Loom Technical
strada integration loom
Easy Fit?
Once the dash is mounted in the vehicle, any qualified auto electrician will be able connect it all within a day, making the IVA Approved Kit Car Dash Kit, a complete solution for kit car and road car Builders, who need a fully IVA compliant Dash Display for their build. With a pre-configured wiring loom, this offers a simple and cost effective legal way, to get a new digital display in your car.
No ECU?
No Problem, we can take a RPM feed from any Coil or Tacho Signal to make it all come alive.
Aim MXS Strada Plug and Play TFT Dash Display
The IVA Approved, 5″ colour ‘Plug and Play’ Car Dash Display, is used on kit cars all over the world. With its clever ECU link, it acquires data from your vehicle engine, making it relatively easy to fit.
Integrated Shift Light Array
High Contrast TFT Display
Aim MXG Strada 1.2 features a high contrast TFT display: its visual quality is always optimal as its ambient light sensor keeps the back light at the best brightness levels. The dash is of course available also in the “Street Icons” version (fuel, oil, water temp etc.)
High Contrast TFT DisplayWatch Your Data in Pre-Configured Pages
The MXG IVA Compliant 7" Plug and Play Dash Kit has a high contrast TFT display and its visual quality is always optimal, as its ambient light sensor keeps the back light at the best brightness levels. The dash is available in the “Street Icons” version needed by street users (fuel, oil, water temp etc.)
Flexible alarms & Custom Street Icons
MXG IVA Compliant 7" Plug and Play Dash Kit features five configurable RGB alarm LED's. You choose the conditions, you choose the colours.  Select a solid alarm or flashing one - and the flashing frequency, choose to have an accompanying text message, and set the alarm priorities. Select then the street icons you need among the wide list you will find in “Race Studio 3 – Icons Management” and set them up the way you prefer or according with your needs. Any of them is fully configurable and if this shouldn’t be enough, you will be able to upload and set up your own customised icons.
Flexible Alarms & Custom Street Icons
Two analogue camera inputs are available, to swap your display into a mirror camera, through push button command or event management.
MXG IVA Compliant 7" Plug and Play Dash Kit is configured via Race Studio 3: you can create, modify, delete, import and export configurations with all channels, ECU drivers, Math channels, Display Pages, Digital output, Alarms, Shift Lights and all the expansions you need.
  • Road Legal MXG  IVA Compliant 7” TFT Colour Display Dash
  • ECU Conection Lead
  • all Software needed
Technical Specifications
Display: 7” TFT
Resolution: 800×480 pixels
Contrast: 1000:1
Brightness: 700cd/m2 – 1,100 Lumen
Ambient light sensor: Yes
Alarm LED's: 8 configurable RGB LED's
Shift lights: 10 configurable RGB LED's
CAN connections: 2
ECU connections: CAN, RS232 or K-Line
ECU compatibility: + 1,000 industry leading ECU's
Expansion CAN connection: GPS, Channel Expansion, TC Hub, Lambda Controller, SmartyCam HD
Analogue inputs: 8 fully configurable, max 1,000 Hz each
Digital inputs: 1 speed input, coil RPM input
Digital outputs: 1 (1 A max)
Second CAN: Yes
Body: Anodized Aluminium
Pushbuttons: Metallic
Connectors: 2 AMP connectors + 1 Binder connector
Power consumption: 400 mA
Dimensions: 237×127.6×26 mm
Weight: 950 g
Waterproof: IP65
MXG Strada 1.2 Technical info
Simple Installation
We have tried to make the installation as simple as possible. The Dash requires power & earth and connecting to the ViM Module. The module has to be connected to your existing Indicators, Lights, etc. using the supplied simple wiring loom. Probably the most complicated part is then using a Multimeter to measure relevant signals to set up items such as your fuel gauge. And that’s it!
Once the dash is mounted in the vehicle (fixing brackets are available) if you prefer, any qualified auto electrician will be able connect it all for you within a day, making the IVA Approved Kit Car Dash Kit a complete solution for Kit Car and Road-Based Vehicle Builders who need a fully IVA compliant Dash Display for their build. Together with the included pre-configured, simple wiring loom the ‘ViM Kit’ offers a highly cost effective legal solution for a digital display in your vehicle.
Download Setup Manual
Customisable Display
Just like modern luxury cars you can choose the Dash display style, from classic round dials to fully digital readouts. Pre-configured layouts of different styles and colours ensure that the Dash is easily configurable using our free RaceStudio 3 software.
You can even switch between the different layouts at any time using the push buttons on the side of the Strada. If the Dash is too far away or you have mounted the display flush into your dashboard, extension cables are available to extend the buttons within easy reach.
Expandable According To Your Needs
As we have a long Motorsport heritage, the MXG Strada Dash can also be connected to other Aim products such as our Data Loggers or Cameras.
MXG 1.2 Strada Connection Examples
ECU Connection
Aim systems acquire data from the ECU of your vehicle. The list of available ECU drivers is constantly updated and upgraded on our support site and are published here. The support site includes over 1,000 different ECU’s both Stock and Racing. They are sorted by manufacturer/vehicle model and for each ECU you find the proprietary communication protocols, including the standard OBDII ones. From a hardware point of view, Aim systems manage the following data lines:
  • CAN
  • RS232
  • K-Line
MXS Strada ECU Connection
MXG Strada Analog Digital Inputs
Aim systems analogue inputs are recorded up to 1,000 times per second each. You can connect and monitor all kinds of sensors, like:
  • Ratiometric potentiometers
  • Pressure sensors
  • Thermo-resistances
  • K-type thermocouples
and many others, all your custom sensors included
MXS Strada Analog Digital Inputs
Aim systems also feature digital inputs:
  • Speed signals – From the ECU, from the GPS and from the wheel sensors.
  • RPM – From the ECU or from a digital input connected to a square wave signal (8 to 50 V) or to a low voltage (from 150 to 400 V) of the coil.
  • Lap signal – Lap and split times are sampled by the GPS or via optical receiver/transmitter
Remote buttons interface More info
GPS08 Module
USB adapter Part number: V02573030
Download the tech sheet
USB cable Part number: X90TMPC002
Loom Pinouts
Pinouts
MXG Strada Downloads
User manual ver. 1.01
Technical sheet
Standard harness for MXP Strada ver. 1.01:
  • Standard harness 23 pins AMP connector (serial protocol)
  • Standard harness 14 pins AMP connector (CAN protocol)
  • USB adapter cable
Harness 14 pins AMP connector – OBDII version ver. 1.00 (CAN and K-Line protocol)
Installation template (scaled 1:1)
Digital outputs ver. 1.03
