Aim MXG 1.2 Powerboat Racing Dash Data logger
£1,925
The 7" MXG 1.2 Powerboat Dash Display with ‘Standard Icons’ has a Superb high contrast mid-size TFT display...
The 7" MXG 1.2 Powerboat Dash Display with ‘Standard Icons’ has a Superb high contrast mid-size TFT display with Customisable RGB shift lights for Racing.
It is designed to acquire and display data from your powerboat engine ECU, the internal accelerometer and gyro, as well as from the GPS08 Module included in the kit, analogue/digital inputs and predefined maths channels.
A Wide Range of Data Sources
Performance and data acquired can also be incremented adding up to eight expansion modules. The only difference between the two is the MXS is a compact 5″ display and Aim MXG 1.2 is a 7″ display, a better fit for wide cockpit installations.
CAN Output
With the CAN Output you can send messages directly to an existing CAN network in order to improve the range of vehicle control possibilities.
MXG – A Wide Range of Data Sources
Freely Configurable Pages
You can define all the custom pages you wish, choosing among a wide library of page styles, defining which data to be shown, their end of scale and measure units. Swapping between pages can be managed pushing one or two push buttons.
High Contrast 7″ TFT display
The MXG 1.2 Powerboat Racing Dash Data logger features a high contrast 7″ TFT display, fully configurable by a dedicated software. An ambient light sensor keeps the back light at optimum brightness levels.
Extra Wide, High Contrast 7″ TFT display
Flexible Alarms
MXG 1.2 Powerboat Racing Dash Data logger features eight configurable RGB alarm LED's: you choose the conditions, you choose the colours.  Select a solid alarm or flashing one - and the flashing frequency, choose to have an accompanying text message, and set the alarm priorities.
Flexible Alarms
MXG 1.2 Dash View
Two Digital Outputs
Aim MXG 1.2 Powerboat Racing Dash Data logger features two digital outputs. Each of them can give an output of 1 amp at 12 volts: they can be configured in order to be turned on/off depending on the value of the analogue or digital inputs. They permit to automatically run external systems, i.e. to switch on/off additional lights, to activate/deactivate a cooling fan or circulation pumps, etc. when a certain event happens.
info
MXGBACK VIEW
Integrated Shift Light Array
Choose from a host of advanced multicoloured RGB shift light patterns that can be customised to your liking, and for each unique gear when required. Using the built-in CAN bus, you can add expansion modules to the Aim MXG to increment the performance and the data acquired.
Expand the system, according to your needs
Using the built-in CAN bus, you can add expansion modules to the MXG 1.2 to increment the performance and the data acquired:
GPS08 Module
Thanks to GPS08 Module (included in the kit) and its Race Studio 3 software, you can immediately get lap times and all data needed for engine tuning as well as for improving driving technique.
Channel Expansion
It permits to add 4 0-5 Volt analogue channels for pressure, temperature sensors and potentiometers. Two of these channels can be configured to receive digital inputs like wheel speed.
TC Hub
It adds 4 K thermocouples.
LCU-One CAN
Wide band Lambda controller LCU-One, with Bosch LSU 4.9 probe, providing all Air/Fuel data and lambda value, allows to perfectly tune the carburetion.
SmartyCam HD cameras
The on-board cameras that overlays on videos the data sampled by your logger.
Race Studio 3 is the heart of your Aim MXG 1.2 managing all your racing activities.
With Race Studio 3 you can create, modify, delete, import and export configurations with all channels, ECU drivers, Maths channels, Display Pages, Digital outputs, Alarms, Shift Lights and all the expansions you need. You will also be able to manage the map of all your racing tracks and compare two laps watching the video recorded by SmartyCam HD cameras.
With Race Studio 3 you can also analyse all data recorded by MXS 1.2 and downloaded to your PC: graphs, histograms and tables will help you study your performance, providing an objective support to avoid mistakes and improve performances
Download RS3
Wi-Fi Connectivity
Makes it even more convenient to configure, calibrate, and download your data wirelessly, using a secure 802.11 WiFi connection: no need to move your PC close to the vehicle anymore, you can do it from your van up to 50 metres away.
Wifi
Get More Data, Win More Races
  • Aim MXG 1.2 Powerboat Racing Dash Data logger
  • 37 Pin standard harness
  • GPS Module with cable
  • USB cable
  • Software installation CD
MXG IN THE BOX
Display : 7″ TFT
Resolution : 800×480 pixels
Contrast : 1,000:1
Brightness : 700cd/m2 – 1,100 Lumen
Ambient light sensor : Yes
Alarm LED's : 8 RGB freely configurable
Shift lights : 10 integrated freely configurable RGB LEDs
CAN connections : 3
ECU connections : CAN, RS232 or K-Line
ECU compatibility : + 1,000 industry leading ECUs
Expansion CAN connection : GPS, Channel Expansion, Thermocouple Expansions, Lambda Controller, SmartyCam HD
Analogue inputs : 8 fully configurable, max 1,000 Hz each
Digital inputs : 4 Speed inputs, lap signal, coil RPM input
Digital outputs : 2 (1 A max each)
Second CAN : Yes
Wi-Fi connection : Yes
Accelerometer : Internal Three-axial ± 5G + Three-axial Gyroscope+ 3 axis magnetometer
Internal memory : 4 GB
Body : Anodised Aluminium
Push buttons : Metallic
Connectors : 2 Motorsport connectors + 1 Binder connector
Power consumption : 400 mA
Dimensions : 237×127.6×26 mm
Weight : 950 g
Waterproof : IP65
MXG Technical 1
MXG Technical 1
MXG Technical 3
22 pins harness
Part number: V02573020
Download the tech sheet
22 pins harness with 1 thermocouple
Part number: V02573080
22 pins harness with 2 thermocouples
Part number: V02573160
37 pins harness with 1 thermocouple
Part number: V02573040
37 pins harness with 2 thermocouples
Part number: V02573050
Remote buttons interface
More info
22 pins female Deutsch connector
Part number: 5CN822F00
37 pins female Deutsch connector
Part number: 5CN837F00
SPARE PARTS
37 pins harness
Part number: V02573010
GPS08 Module
More info
USB adapter
Part number: V02573030
USB cable
Part number: X90TMPC002
