AiM MXL2 Racing Dash Logger
The MXL2 is a powerful dash logger for all racers. It acquires & displays data coming from the ECU.
Key Features:
With an improved LCD screen featuring dual coloured backlights, WiFi connectivity and housed in a waterproof aluminium chassis. Designed to acquire and display data coming from your ECU, the internal accelerometer and gyro, the GPS module included in the kit, analogue/digital inputs and predefined math channels. Performance and data acquired can also be incremented by adding up to eight expansion modules. Supplied complete with a GPS08 module, wiring harness with military spec motorsport connectors, data lead and the powerful RaceStudio3 software. All versions include an odometer and trip meter. |
The MXL2 also features two digital outputs. Each of them can give an output of 1 amp at 12 volts: they can be configured in order to be turned on/off depending on the value of the analogue or digital inputs. They permit to automatically run external systems, i.e. to switch on/off additional lights, to activate/de-activate a cooling fan or circulation pumps, etc when a certain event happens. |
An integrated 10 LED shift light. Choose from a host of advanced multi-coloured RGB shift light patterns that can be customised to your liking, and for each unique gear when required. |
GPS08 Module
MXL2 Connection Example |
Pin HarnessThe 37 pin harness comes standard in the kit, should you need more data you can add our 22 pin harness as an optional extra. |
MXL2 Car Racing Dash Logger
- Display: LED display + graphical portion
- Backlight: White or red
- Ambient light sensor: Yes
- Alarm LEDs: 6 RRB freely configurable
- Shift lights: 10 integrated freely configurable RGB LEDs
- CAN connection: 3
- ECU connections: CAN, RS232 ot K-Line
- ECU compatibility: + 1000 industry leading EUCs
- Expansion CAN connection: GPS, channel expansion, thermocouple expansions, lambda controller, Smartycam HD
- Analog inputs: 8 fully configurable, max 1 KHz each
- Digital inputs: 4 speed inputs, lap signal, coli RPM input
- Digital outputs: 2 (1A max each)
- Second CAN: Yes
- Accelerometer: Internal three axial + 5G three axial gyroscope
- Internal memory: 4 GB
- Body: Anodised Aluminium
- Connectors: 2 motorsport connectors
- Power consumption: 400mA
- Dimensions: 187.8x103x21mm
- Weight: 530g
- MXL2 Racing Dash Logger
- 37 Pin standard harness
- GPS Module with cable
- USB Cable
