AiM MXL2 Ducati Kit
SKU: MXL2-DUC-1
- £1,700.00
- £1,700.00
AiM MXL2 Ducati Kit
The MXL2 is a powerful dash logger for all racers. It acquires & displays data coming from the ECU.
High contrast LCD | Fully Plug & Play |
6 configurable RGB alarm LEDs | 10 LED shift lights |
Define up to 8 custom pages | Two digital outputs |
Wi-Fi connectivity | GPS & track management |
AiM MXL2 Ducati Kit
With an improved LCD screen featuring dual coloured backlights, WiFi connectivity and housed in a waterproof aluminium chassis. Designed to acquire and display data coming from your ECU, the GPS module included in the kit, analogue/digital inputs and predefined math channels.
Performance and data acquired can also be incremented by adding up to eight expansion modules. Supplied complete with a GPS module, wiring harness with military spec motorsport connectors, data lead and the powerful Race Studio 3 software. All versions include an odometer and trip meter.
Connecting the MXL2 to your ECU standard vehicle or racing ECU is very simple. Sample and display dozens of channels straight from the vehicle’s ECU. This is often the quickest and easiest setup, needing only a cable connection to the ECU instead of multiple connections to analogue sensors. Sampled data depends on the actual ECU but typically includes RPM, engine load, throttle position TPS, oil/air/water temperature, oil pressure, battery voltage, speed, gear, lambda value, air/fuel ratio. The list of available ECU drivers is constantly updated and upgraded includes around 1000 different ECUs, either O/E or racing.
2 Digital Outputs
The MXL2 also features two digital outputs. Each of them can give an output of 1 amp at 12 volts: they can be configured to be turned on/off depending on the value of the analogue or digital inputs. They permit to automatically run external systems, i.e. to switch on/off additional lights, to activate/de-activate a cooling fan or circulation pumps, etc when a certain event happens.
The MXL2 display features a high contrast traditional LCD, combined with a graphical LCD offering great flexibility in information display and alerts. The MXL2 offers a dual coloured backlight of high contrast white or red. An ambient light sensor keeps the backlight at optimum brightness levels.
Integrated Shift Light
An integrated 10 LED shift light. Choose from a host of advanced multi-coloured RGB shift light patterns that can be customised to your liking, and for each unique gear when required.
Flexible Alarms
Six different alarm LEDs: you choose the conditions, the colours and the flashing frequency. You can configure them to turn them on/off depending on analogue or digital inputs, ECU values, expansion values, GPS information or math channels. You can also associate an alarm LED a message and a digital output with each event.
GPS Module
Included with the dash, GPS technology represents a true revolution in data acquisition. Thanks to the lightweight and waterproof GPS Module and its GPS Manager software, you can immediately get lap times and all data needed for engine tuning as well as for improving driving technique.
Pin Harness
These are only some of the items that can be added to our MXL2 for incrementing the performance and the data acquired :
With Race Studio 3 you can also analyse all data recorded by MXL2 and downloaded to your PC: graphs, histograms and tables will help you study your performance, providing an objective support to avoid mistakes and improve performances.
AiM MXL2 Ducati Kit
- Display : LED display + graphical portion
- Backlight: White or red
- Ambient light sensor: Yes
- Alarm LEDs: 6 RRB freely configurable
- Shift lights: 10 integrated freely configurable RGB LEDs
- CAN connection : 3
- ECU connections: CAN, RS232 or K-Line
- ECU compatibility : + 1000 industry-leading EUCs
- Expansion CAN connection: GPS, channel expansion, thermocouple expansions, lambda controller, Smartycam HD
- Analogue inputs: 8 fully configurable, max 1 kHz each
- Digital inputs: 4-speed inputs, lap signal, coil RPM input
- Digital outputs: 2 (1A max each)
- Second CAN: Yes
- Internal memory: 4 GB
- Body: Anodised Aluminium
- Connectors: 2 motorsport connectors
- Power consumption : 400mA
- Dimensions : 187.8x103x21mm
- Weight: 530g
AiM MXL2 Ducati Kit
- MXL2 Racing Dash Logger
- 37 Pin standard harness
- GPS Module with cable
- USB Cable
AiM MXL2 Ducati Kit
The MXL2 is a powerful dash logger for all racers. It acquires & displays data coming from the ECU.Key Features :
AiM MXL2 Ducati Kit
With an improved LCD screen featuring dual coloured backlights, WiFi connectivity and housed in a waterproof aluminium chassis. Designed to acquire and display data coming from your ECU, the GPS module included in the kit, analogue/digital inputs and predefined math channels.Performance and data acquired can also be incremented by adding up to eight expansion modules. Supplied complete with a GPS module, wiring harness with military spec motorsport connectors, data lead and the powerful Race Studio 3 software. All versions include an odometer and trip meter.
Connecting the MXL2 to your ECU standard vehicle or racing ECU is very simple. Sample and display dozens of channels straight from the vehicle’s ECU. This is often the quickest and easiest setup, needing only a cable connection to the ECU instead of multiple connections to analogue sensors. Sampled data depends on the actual ECU but typically includes RPM, engine load, throttle position TPS, oil/air/water temperature, oil pressure, battery voltage, speed, gear, lambda value, air/fuel ratio. The list of available ECU drivers is constantly updated and upgraded includes around 1000 different ECUs, either O/E or racing.2 Digital Outputs
The MXL2 also features two digital outputs. Each of them can give an output of 1 amp at 12 volts: they can be configured to be turned on/off depending on the value of the analogue or digital inputs. They permit to automatically run external systems, i.e. to switch on/off additional lights, to activate/de-activate a cooling fan or circulation pumps, etc when a certain event happens.Display
The MXL2 display features a high contrast traditional LCD, combined with a graphical LCD offering great flexibility in information display and alerts. The MXL2 offers a dual coloured backlight of high contrast white or red. An ambient light sensor keeps the backlight at optimum brightness levels.Integrated Shift Light
An integrated 10 LED shift light. Choose from a host of advanced multi-coloured RGB shift light patterns that can be customised to your liking, and for each unique gear when required.Flexible Alarms
Six different alarm LEDs: you choose the conditions, the colours and the flashing frequency. You can configure them to turn them on/off depending on analogue or digital inputs, ECU values, expansion values, GPS information or math channels. You can also associate an alarm LED a message and a digital output with each event.GPS Module
Included with the dash, GPS technology represents a true revolution in data acquisition. Thanks to the lightweight and waterproof GPS Module and its GPS Manager software, you can immediately get lap times and all data needed for engine tuning as well as for improving driving technique.The GPS Module is fast in satellite signal acquisition and reliable in adverse situations. GPS Manager allows you to set track start/finish lines and splits and to download a comprehensive track database. With the GPS Module you get important information, i.e. chassis analysis, track position, etc as well as position, speed, cornering in-line and lateral G and automatic lap times.
Pin Harness
With Race Studio 3 you can also analyse all data recorded by MXL2 and downloaded to your PC: graphs, histograms and tables will help you study your performance, providing an objective support to avoid mistakes and improve performances. ![]() |
AiM MXL2 Ducati Kit
- Second CAN: Yes
- Weight: 530g
360° View
AiM MXL2 Ducati Kit
- USB Cable
