AiM MXP Display Cowl
£104
AiM MXP Display Cowl Check out our MXP Display Cowl offering a solution to sun glare and protection...
Check out our MXP Display Cowl offering a solution to sun glare and protection with a perfect finish for your dash.
Key Features:
  • Lightweight
  • Textured finish
  • Reduces sun glare
  • Honeycomb construction
The AiM MXP Display Cowl
Our AiM MXP Display Cowl offers protection from sun glare and gives the perfect finish for your dash.
It will protect the dash and screen from frontal impacts, such as stones.
While helping to reduce sun glare it high lights the screens brightness.
The AiM MXP Display Cowl is lightweight and made with a honeycomb construction and a textured finish.
It makes a stylish home for your MXP.
AiM Product Video
  • Lightweight
  • Honeycomb Construction
    Search compatible ECU's by manufacturer supported by AiM
    Click here >
    User Guide
    Technical sheet
