Aim MXP Strada Dash Display Standard Icons – AimShop.com
SKU: MXP-S-ODB11
Availability: 50 in stock
£990.00
QTY:
Trust Badge
The Aim MXP Strada Dash Display Standard Icons offers 50% more display area than the 5'' MXS display, in a similar dimension. The dash logger has an integrated shift array, configurable multicolor alarms, drag and drop multi page configuration, Wi-Fi and USB connectivity, GPS Module, inertial platform, analog and digital inputs, digital outputs, Motorsport connectors, 4 GB of internal memory, 1,000Hz per channel sampling and support for over 1,000 ECU connections.
MXP Strada samples data coming from your ECU, the GPS Module, the 9 axis inertial platform (accelerometer, gyro and magnetometer), 8 fully configurable analog inputs, 6 digital inputs, predefined math channels and second CAN. Performance and data acquired can also be incremented adding up to eight expansion modules.
Aim MXP Strada is available in two versions:
mxp versions
Freely configurable pages
You can define all the custom pages you wish, choosing among a wide library of page styles, defining which data to be shown, their end of scale and measure units. Swapping between pages can be managed pushing one or two push buttons.
 High Contrast TFT Display
Aim MXP features a high contrast TFT display: its visual quality is always optimal as its ambient light sensor keeps the back light at the best brightness levels. The dash is of course available also in the “Street Icons” version (fuel, oil, water temp etc.)
High contrast TFT display
Flexible alarms & custom street icons
MXP features five configurable RGB alarm LED's. You choose the conditions, you choose the colours.  Select a solid alarm or flashing one - and the flashing frequency, choose to have an accompanying text message, and set the alarm priorities. Select then the street icons you need among the wide list you will find in “Race Studio 3 – Icons Management” and set them up the way you prefer or according with your needs. Any of them is fully configurable and if this shouldn’t be enough, you will be able to upload and set up your own customised icons.
Two Digital Outputs
MXP features two digital outputs. The two digital outputs (Dout) are LOW SIDE type (switch to ground): they can be configured in order  to be turned on/off depending on the value of the analog or digital inputs. They permit to automatically run external systems, i.e. to switch on/off additional lights, to activate/de-activate a cooling fan or circulation pumps, etc. when a certain event happens.
more info
MXP STRADA BACK VIEW
Two analog camera inputs are available, to swap your display into a mirror camera, through pushbutton command or event management.
Integrated shift light array
Choose from a host of advanced multicoloured RGB shift light patterns that can be customised as you like and also for each unique gear when required.
Aim MXP Strada Connection Examples
mxp connections
CAN output
With the CAN Output you can send messages directly  to an existing CAN network in order to improve  the range of vehicle control possibilities.
 CAN output
Race Studio 3 is the heart of your MXS, managing all your racing activities. The Race Studio 3 can create, modify, delete, import and export configurations with all channels, ECU drivers, Math channels, Display Pages, Digital outputs, Alarms, Shift Lights and all the expansions you need. You will also be able to manage the map of all your racing tracks and compare two laps watching the video recorded by SmartyCam HD cameras.
With Race Studio 3 you can also analyse all data recorded by MXS 1.2 and downloaded to your PC: graphs, histograms and tables will help you study your performance, providing an objective support to avoid mistakes and improve performances
Get More Data, Win More Races
Wide range of data sources
Analog Digital Inputs
MXL2 has eight analog inputs, recorded up to 1000 times per second each. You can connect and monitor all kinds of sensors, like:
Ratiometric potentiometers
Pressure sensors
Thermo-resistances
K-type thermocouple and many others, all your custom sensors included.
Features six digital inputs
Four speed signals – It can receive the speed signal from the ECU, from the GPS and from the four wheel sensors.
  • RPM – can receive the RPM signal from the ECU or from a digital input connected to a square wave signal (8 to 50 V) or to a low voltage (from 150 to 400 V) of the coil.
  • Lap signal – Lap and split times are sampled by the GPS (included in the kit) or via optical receiver/transmitter.
GPS Module
The GPS08 Module (included in the kit) connected via CAN makes lap time calculation and track position analysis very easy. Each Aim memory stores more than 200 world tracks start/finish line coordinates. As soon the dash/logger is switched on, the GPS08 Module will locate its position, identify track-line coordinates and start immediately sampling lap and split time.
If the track is not included in the database, it is always possible to add the start/finish line coordinates to the Aim MXL2 via PC before going to the track, using the Race Studio 3 – Track Manager software.
Second CAN
An innovative feature is the CAN 2 line, managing data coming from your additional modules (i.e. ABS, traction control, infrared temperature sensors and more) This feature meets the requirements of a growing number of racers, as the use of additional modules is becoming quite common in a number of series.
Internal Accelerometer and Gyro
The internal three-axial accelerometer and the gyroscope provide a very powerful array of information. These force and motion sensors enable you to quantify the dynamic characteristics of your vehicle. Measuring acceleration forces and gyro rates can assist in determining how to improve your vehicle performances.
Math Channels
You immediately get Math Channels values. The dash logger can be configured to display those values (i.e. brake bias, calculated gear) in real time.
Technical Specifications
Display: 6” TFT
Resolution: 800x480 pixels
Contrast: 600:1
Brightness: 700cd/m2 - 1,100 Lumen
Ambient light sensor: Yes
Alarm display icons: Yes, freely configurable
Shift lights: 10 integrated freely configurable RGB LEDs
Alarm LED: 5 integrated freely configurable RGB LEDs
CAN connections: 3
ECU connection: CAN, RS232 or K-Line
ECU compatibility: 1,000+ industry leading ECUs
Expansion CAN connection: GPS Module, Channel Expansion, Thermocouples expansions,Lambda Controller, SmartyCam HD
Analog inputs: 8 fully configurable, max 1,000 Hz each
Digital inputs: 1 Speed input, coil RPM input
Digital outputs: 1 (1 A max)
Second CAN: Yes
Body: Anodized Aluminum
Pushbuttons: Metallic
Connectors: 2 AMP connectors
Power consumption: 400 mA
Dimensions: 189.6 x 106.4 x 24.9 mm
Weight: 640 g
Waterproof: IP65
XA5MXPSTRA010 – MXP Strada with CAN harness (ECU)
XA5MXPSTRA020 – MXP Strada with OBD harness CAN+K (ECU)
XA5MXPSTRI010 –  MXP Strada Street icons version with CAN harness (ECU)
XA5MXPSTRI020 –  MXP Strada Street icons version with OBD harness CAN+K (ECU)
TECH1TECH2TECH3PINOUTPINOUT 2
In the Box
  1. MXP Strada Dash Display Standard Icons
  2. USB cable,
  3. 14 pins standard wiring,
  4. 23 pins connector + contacts,
  5. software installation CD.
    Reversing Camera
    The Video In connector allows the connection of two different analog cameras, that may be activated as here down described.
    This camera offers a couple of interesting options,
    • The possibility to reverse the image
    • The possibility to enable or disable the parking overlay view
    read more
    Accessories
    22 pins harness
    Part number: V02573020
    Download the tech sheet
    22 pins harness with 1 thermocouple
    Part number: V02573080
    22 pins harness with 2 thermocouples
    Part number: V02573160
    37 pins harness with 1 thermocouple
    Part number: V02573040
    37 pins harness with 2 thermocouples
    Part number: V02573050
    Remote buttons interface
    More info
    22 pins female Deutsch connector
    Part number: 5CN822F00
    37 pins female Deutsch connector
    Part number: 5CN837F00
    SPARE PARTS
    37 pins harness
    Part number: V02573010
    GPS08 Module
    More info
    USB adapter
    Part number: V02573030
    USB cable
    Part number: X90TMPC002
