AiM MXP Strada Road Icons Dash Display
£825
AiM MXP Strada Road Icons Dash Display The MXP Strada Dash features a 6" wide colour TFT display...
The MXP Strada Dash features a 6" wide colour TFT display with great visual impact.
Key Features:
  • 6" TFT display
  • 1000 + ECU connections
  • Ambient Light Sensor
  • 10 multi-coloured RGB shift lights
  • 8 analogue inputs
  • 6 digital inputs
  • Second CAN
  • Two digital outputs
  • Configurable pages
  • Free race studio 3 download
Aim MXP Strada with Road Icons
The AiM Strada Dash features a 6" wide colour TFT display offering a great visual impact. The MXP is configurable to show all the data coming from your vehicles Engine Control Unit (ECU). 9 axis internal platform - accelerometer, gyro and magnetometer, 8 analogue inputs, 6 digital inputs, pre-defined math channels, a second CAN and optional GPS08 Module.
Connecting the MXP Strada dash to your car/motorcycle ECU (standard or racing) is very simple. You can sample and display dozens of channels straight from the ECU. This is usually the quickest setup, needing only two cable connections to the ECU instead of multiple connections to analogue sensors.
The sampled data depends on the actual ECU but normally included RPM, throttle position (TPS), oil, air, water temperature, oil pressure, battery voltage, speed, gear, lambda value (air, fuel ratio). The list of available ECU drivers 1,000+ and is constantly being updated and added to.
Pre-Configured Pages
The MXP Strada shows with RPM scale all the data you need, such as speed, water temperature and oil pressure and lots more. You can choose the custom pages you wish, including up to four additional fields, from large library of page styles, defining which data you want to be shown - their end of scale measure units. Swapping between pages is easy using the push buttons.
Flexible Shift Lights & Alarms
The MXP has 10 multi-coloured RGB shift lights can be customised to how you like them. Defining the RPM threshold for each single gear. The same flexibility applies to the configurable RGB alarm LEDs. You can configure them in order to turn them on/off depending on analogue or digital inputs.ECU values, expansion values, math channels or optionally a GPS08.
You choose the conditions and colours, you can select a solid alarm or a flashing one, also the flashing frequency. It is also possible to configure an accompanying text message on the display and set the alarm priorities.
High Contrast TFT Display
The MXP Strada has a 6" high contrast TFT display. It's visual quality is optimised by it's ambient light sensor which keeps the backlight at the best brightness levels, avoiding the screen from dazzling you when it gets dark, yet keeping it bright and visual during the day.
Two Digital Outputs
The MXP Strada has two digital outputs. These LOW SIDE type (switch to ground), can be configured in order to be activated/deactivated depending on the value of the analogue/digital outputs. This allows you to automatically run external systems, such as switch on/off additional lights or to activate/de-activate a cooling fan or circulation pumps etc when a certain event happens.
MXP 1.2 Strada Connection Example
Below is an example of items that can be added to our MXP Strada for incrementing the performance and the data.
Turn Your Dash/Logger Into A Rearview Mirror
The MX Series is now available to manage up to two rear cameras.
Compare AiM Dashes
  • Display: 6" TFT
  • Resolution: 800x480 pixels
  • Contrast: 600:1
  • Brightness: 700cd/m2-1,100 Lumen
  • Ambient Light Sensor: Yes
  • Alarm display icons: Yes, freely configurable
  • Shift lights: 10 integrated freely configurable RGB LEDs
  • Alarm LED: 5 integrated freely configurable RGB LEDs
  • CAN connections: 3
  • ECU connection: CAN, RS232 or K-Line
  • ECU compatibility: 1,000 + industry leading ECUs
  • Expansion CAN connection: GPS Module, Channel Expansion, Thermocouples expansions, Lambda Controller, SmartyCam HD
  • Analog inputs: 8 fully configurable, max 1,000 Hz each
  • Digital inputs: 1 Speed input, coil RPM input
  • Digital outputs: 1 (1 A max)
  • Second CAN: Yes
  • Body: Anodised Aluminium
  • Pushbuttons: Metallic
  • Connectors: 2 AMP connectors
  • Power consumption: 400 mA
  • Weight: 640g
Search compatible ECU's by manufacturer supported by AiM
Click here >
AiM MXP 360° View
  • MXP Strada
  • 14 pins standard cable
  • 23 pin connector + contacts
