AiM MXS 1.2 Strada Dash Display Standard Icons
£750
AiM MXS Strada Dash Display Check your vehicle  compatibility Manufacturer ECU Aftermarket ECU If you are unable to...
Manufacturer ECU
Aftermarket ECU
If you are unable to locate your vehicle don’t worry our AiM products are capable of fitting all ECU’s.
Please contact us via chat service below or by email: sales@aimshop.com
AiM 5" MXS 1.2 Strada Display with Standard Icons
The MXS Strada with race icons is one of the most widely used dashes on tracks and streets all over the world.
Key Features:
  • 5" TFT display
  • 1000+ ECU connections
  • CAN output
  • 10 RGB shift lights
  • Two digital outputs
  • Define up to 8 custom pages
  • 14 pin harness
  • Math channel
  • 6 alarm LEDs
  • 8 analog inputs
  • Ambient light sensor
  • Free race studio 3 download
 AiM MXS 1.2 Strada with Race Icons
The AiM MXS 1.2 Strada dash is one of the most widely used dashes on tracks and streets around the globe. The MXS 1.2 Strada dash has a 5" colour TFT display which has been designed to give a great visual impact, configurable to show all the information coming from the ECU analogue  / digital inputs, pre-defined math channels and an optional GPS Module.
The MXS 1.2 Strada has a wide contrast TFT display, its visual quality is optimised as its ambient light sensor keeps the back light at the best brightness.
Connecting the MXS 1.2 Strada dash to your ECU is very simple. You can sample and display dozens of channels from the vehicles ECU. This is usually the quickest and easiest setup needing only two cable connections to the ECU instead of multiple connections to analogue sensors.
The sampled data depends on the actual ECU but typically includes RPM, throttle position (TPS) oil, air, water temperature, oil pressure, battery voltage, speed gear lambda value (air, fuel ratio). There is a list of over 1000+ ECU drivers which are constantly being updated.
Pre-Configured Pages
The MXS 1.2 Strada shows together with the RPM scale showing the data you need like speed, water temperature, oil pressure, lap time and much more.
You can choose the custom pages you wish from a large library of page styles. You decide what data to be shown and the end scale and measure units. Also swapping between pages is easy using the pushbuttons.
High Contrast TFT Display
The MXS 1.2 Strada features a high contrast TFT display, its visual quality is always optimal as its ambient light sensor keeps the backlight at the best brightness levels.
Flexible Shift Lights and Alarms
The MXS 1.2 Strada has 10 multi-coloured RGB shift lights which can be customised to your liking to define the RPM threshold for each single gear. The same flexibility applies to the configurable RGB alarm LEDs. You can configure them in order to turn them on / off depending on the analogue or digital inputs, ECU values, expansion values, math channels or optional GPS08 information.
Two Digital Outputs
Turn Your Dash/Logger Into A Rearview Mirror
The MX Series is now available to manage up to two rear cameras.
MXS 1.2 Strada Connection Example
Below is an example of items that can be added to our MXS Strada for incrementing the performance and your data.
Not Enough
The Strada Logger Kit turns any MX Strada into a full-working data logger.
Our Aim Strada Logger Kit comprises of our Aim Strada Logger, Data Hub, GPS08 Module.
This kit will turn any MX Strada into a full working data logger which will be able to collect data ready to be analysed on Race Studio 3, also help you improve  your driver performance and identify any possible improvements in your vehicle setup.
Compare AiM Dashes
AiM Product Video
MXS 1.2 Strada Dash Display with Standard Icons
  • Display: 5" TFT
  • Resolution: 800x480 pixels
  • Contrast: 600:1
  • Ambient light sensor: Yes
  • Alarm LEDs: 6 RGB freely configurable
  • Shift lights: 10 integrated freely configurable RGB LEDs
  • CAN connections: 2
  • ECU connections: CAN, RS232 or K-Line ECU
  • Compatibility: +1000 industry leading ECUs
  • Expansion CAN connection: GPS, Channel expansion, TC hub, Lambda controller, SmartyCam HD
  • Analog inputs: 8 fully configurable, max 1000 Hz each
  • Digital inputs: 1 speed input, coil RPM input Digital outputs 1 (1 A max
  • Second CAN: Yes
  • Body: Anodised Aluminium
  • Pushbuttons: Metallic connectors: 2 AMP connectors
  • Power consumption: 400 mA
  • Dimensions: 169.4x97x23mm
  • Weight: 480g
Search compatible ECU's by manufacturer supported by AiM
Click here >
AiM MXS 1.2 Strada 360° Product View
  • MXS 1.2 Strada
  • 14 Pins Standard Wiring
  • 23 Pins Connector + Contacts
  • Software Installation CD
