Aim MXS 1.2 Strada Dash Display Street Icons – Aim Shop - Motorsport Data Loggers, Displays and Laptimers
SKU: MXS-S-I-ODB11
Availability: 28 in stock
£900.00
QTY:
Trust Badge
The Aim MXS 1.2 Strada Dash Display Street Icons is the the evolution of MXS Strada which is a  5″ color display with great visual impact. It is configurable to show lap times and all the info coming from the Engine Control Unit like analog/digital inputs, pre-defined math channels and optionally, the GPS08 Module.
MXS 1.2 Strada is available in two versions:
CAN Output
Watch Your Data in Pre-Configured Pages
The MXS Strada has a high contrast TFT display and its visual quality is always optimal, as its ambient light sensor keeps the backlight at the best brightness levels. The dash is available in the “Street Icons” version needed by street users (fuel, oil, water temp etc.)
High Contrast TFT Display
The Aim MXS 1.2 Strada shows with RPM scale, all the data you need, like speed, water temperature and oil pressure, lap times and much more. You can choose the custom pages you wish, including up to four additional fields
A wide library of page styles, defining which data to be shown, their end of scale and measured units. Swapping between pages is quite easy with the Aim MXS Strada using the push buttons provided.
Flexible Shift Lights and Alarms
The ten multi-coloured RGB shift lights on the MXS Strada can be customised to your liking to define the RPM threshold for each single gear. The same flexibility applies to the configurable RGB alarm LED's. You can configure them in order to turn them on/off depending on analog or digital inputs, ECU values, expansion values, math channels or, optionally, GPS information. You choose conditions and colours and you can select a solid alarm or flashing one and the flashing frequency. It is also possible to configure an accompanying text message along with the alarm priorities.
CAN Output
With the CAN Output you can send messages directly to an existing CAN network in order to improve the range of vehicle control possibilities.
Two Digital Outputs
Aim MXS Strada features a LOW SIDE type (switch to ground) digital output configurable in order to be activated/deactivated depending on the value of the analogue / digital inputs or on impulses coming from the ECU. This permits to automatically run external systems, i.e. to switch on/off additional lights, to activate/de-activate a cooling fan or circulation pumps, etc. when a certain event happens.
Two Digital Outputs
More info
MXS Strada Connection Examples
Race Studio 3 is the heart of your MXS 1.2 Strada managing all your racing activities
With Race Studio 3 you can also analyse all data recorded by MXG and downloaded to your PC: graphs, histograms and tables will help you study your performance, providing an objective support to avoid mistakes and improve performances.
Download
A Wide Range of data sources
MXG is the dashlogger designed to acquire and display data coming from your ECU, the internal accelerometer and gyro, as well as from the GPS08 Module included in the kit, analog/digital inputs and predefined math channels. Performance and data acquired can also be incremented adding up to eight expansion modules. Its 7″ display makes it perfect for wide cockpits installation.
In The Box
  • MXS 1.2 Strada
  • USB cable
  • 14 pin standard wiring
  • 23 pin connector + contacts
  • Software installation CD
MXS Strada Technical Specifications
Display: 5" TFT
Resolution: 800x480 pixels
Contrast: 600:1
Brightness: 700cd/m2 - 1,100 Lumen
Ambient light sensor: Yes
Alarm LEDs: 6 RGB freely configurable
Shift light: 10 integrated freely configurable RGB LEDs
CAN connections: 2
ECU connections: CAN, RS232 or K-Line
ECU compatibility: + 1,000 industry leading ECUs
Expansion CAN connection: GPS, Channel Expansion, TC Hub, Lambda Controller, SmartyCam HD
Analog inputs: 4 fully configurable, max 1,000 Hz each
Digital inputs: 1 speed input, lap signal, coil RPM input
Digital outputs: 1 (1 Amp max)
Second CAN: Yes
Body: Anodized Aluminum
Pushbuttons: Metallic
Connectors: 2 AMP connectors
Dimensions: 169.4x97x23 mm
Weight: 480 g
Power consumption: 400 mA
Waterproof: IP65
Aim MXS Strada tech spec
strada pinout
Accessories
22 pins harness Part number: V02573020
Download the tech sheet
22 pins harness with 1 thermocouple Part number: V02573080
22 pins harness with 2 thermocouples Part number: V02573160
37 pins harness with 2 thermocouples Part number: V02573050
Remote buttons interface More info
22 pins female Deutsch connector Part number: 5CN822F0
37 pins female Deutsch connector Part number: 5CN837F00
Spare Parts
37 pins harness Part number: V02573010
GPS08 Module
USB adapter Part number: V02573030
USB cable Part number: X90TMPC002
