Skip to product information
1 of 4
AiM Oil / Fuel Pressure Sensor 1/8th NPT 0-10 Bar
SKU: S-P-O-NPT
£190.00
£190.00
All deliveries are carbon neutral
Powered by Shopify Planet
The AiM 1/8th NPT 0-10 Bar pressure sensor is suitable for oil and fuel pressure readings and able to read pressures up to 10 bars.
1/8th NPT 0-10 Bar 4 pins 719 male binder
The 1/8th NPT 0-10 Bar pressure sensors are fitted with male four pins black 719 binder plug connections to suit all AIM loggers and dash display/loggers. Many things affect the various engine pressures, and knowing that your engine has the correct amount is paramount to longevity and performance. Suitable for oil, fuel and water pressure readings.
  • Supply: 8-16V
  • Consumption: < 10 mA
  • Sealing: IP66
  • Weight: 30g
  • Cable Length: 400mm
  • Thread: 1/8th NPT
  • AiM Oil/Fuel pressure sensor 1/8th NPT 0-10 Bar
  • Supply: 8-16V
  • Sealing: IP66
  • Weight: 30g
  • Thread: 1/8th NPT
