AiM PDM Dash LVDS Cable 2M
£135
PDM Dash LVDS Connector Cable The PDM has a external high speed link used to manage remote display....
Key Features:
  • Transmits to remote display
  • Receives light sensor data
  • Reliable to power display
The PDM has an external high speed link used to mange the remote display. The link transmits to the remote display all the TFT Screen information and the status LEDs activity. Also receives display light sensors data and push buttons status.
This link is also used to power the remote display making a simple and reliable connection.
Rosenberger connectors allow high immunity noise levels and IP67 class connection.
    AiM PDM Dash LVDS Cable 2M FCCA 682000
    • Mating Cycles: >25
    • Engagement Force: < 30N
    • Engagement Force Waterproof: <40N
    • Retention Force Latch: > 110N
    • Disengagement Force: > 5N
    • Retention Force Primary Lock: > 80N
    • Retention Force Secondary Lock: > 60N
    • Polarisation feature effectiveness: > 80N
    • Temperature Range: -40°C + 105°C
    • Thermal Shock IEC: 60068-2-64
    • Vibration IEC: 60068-2-64
      Technical sheet
