AiM PDM08 Data Logging Power Distribution Module Only
SKU: PDM08-XC1PDM0802G050
- £1,010.00
- £1,010.00
Available for Pre-Order - Delivery January 2021
AiM PDM08 Power Distribution Module.
The AiM PDM08 has been designed to distribute power to multiple circuits on your vehicle.
Key Features:
Power Distribution Module 08The AiM PDM08 is an 8-channel advanced power distribution module designed to power a multitude of vehicle circuits removing the need for the traditional fuse boxes and relays. It allows for a simplified wiring harness with increased reliability and control functions. The PDM08 is available on its own like this one or with a choice of 6"" or 10"" dash displays. The PDM08 is also capable of receiving data from the vehicle's ECU and even includes a data logger and GPS module for lap liming and track mapping. (See listing for PDM08 with GPS). Simplifies electronic installations with greater control. 8 outputs, ideal for controlling vehicle electrical circuits. Built-in data logging facility to log all PDM outputs and ECU data plus lap timing. Dash controller with 6"" or 10"" dash display options. GPS Module options for lap timing and track mapping. Rugged aluminium case designed to stand harsh Motorsport environments. |
PDM Power Outputs
The AiM PDM08 features 8 x 15A current outputs with a total continuous max current of 120A. Each of the outputs provides feedback to the data logger to provide vital information such as open circuits, short circuits, high/low voltage, the number of fault retires and the time between the reties is user definable. All outputs can be configured as PWM's for a soft start/stop. All the PDM circuits can be set up and monitored within our Race Studio 3 Software. |
The PDM08 features 6 x analogue / digital inputs and 2 x speed inputs. |
Dash Display Option ( Not Included)
Suitable for replacing all of the dashboard gauges and wiring lamps, these TFT dash displays are available in 6"" or 10"" versions. Both versions have fully configurable displays and offer a range of layouts. These displays can also double up as a reversing mirror by using our separate camera, which is sold separately. Ideal for cars with limited rear vision. Up to two cameras can be added for both front and rear views. The mirror camera connects to the PDM through the 5-pin binder connector. |
- Input - 6 fully configurable, max 500 Hz each
- Power Outputs - 8 rated up to 20 A (mid power) Protected for: over voltage, under voltage, over current, over temperature
- Lin Bus - 1
- CAN Connections - 3
- Intertial Platform - 3 axis + 5G accelerometer + 3 axis gyro + axis magnetometer
- Internal Memory - 4 GB
- External Modules - GPS Module, Channel Expansion, TC Hub, Lambda Controller, SmartyCam HD, Formula Steering Wheel, Remote I/O Pushbutton Module.
- External Analogue Camera Input - NO
- Body - Anodised Aluminium
- Waterproof - IP65
- Dimensions - 161 x 1000.6 x 50.6mm
PDM Power Outputs
Dash Display Option ( Not Included) Suitable for replacing all of the dashboard gauges and wiring lamps, these TFT dash displays are available in 6"" or 10"" versions. Both versions have fully configurable displays and offer a range of layouts. These displays can also double up as a reversing mirror by using our separate camera, which is sold separately. Ideal for cars with limited rear vision. Up to two cameras can be added for both front and rear views. The mirror camera connects to the PDM through the 5-pin binder connector.
Technical Specifications
- Lin Bus - 1
- Waterproof - IP65
ECU Connections & Support
Whats in The Box
