AiM PDM32 With GPS Sensor, Data Logging and TFT Screen Included
£1,650
The Aim PDM32 Power Distribution Module is designed to effortlessly replace traditional fuse and relay systems by distributing...
The Aim PDM32 Power Distribution Module is designed to effortlessly replace traditional fuse and relay systems by distributing power to various circuits in your vehicle.
With 28 high side outputs and 4 half bridge outputs – the PDM32 is central to your vehicle’s electronics system. This gives you greater control and simplifies the wiring harness and electronic installations.
Housed in an anodised billet aluminium case, this PDM is designed to tackle the harsh conditions of Motorsport and includes a complete professional data logger and internal dash controller.
Please Note: Our CAN Keypads have been specifically designed to work with our Power Distribution Systems. No other keypads will work with this system. We offer keypads in 4, 6, 8 and 12 button and they can be found under CAN Buttons & Switches.
Features
  • ECU connection to acquire data from your vehicle’s ECU
  • Built-in data logger that saves you the need to buy an external logger
  • GPS Module to display and record automatic lap times and track positions
  • Dash controller for managing the 6” or 10” dash display
  • 9 axis EMU platform
  • Mirror camera for back view while reversing
PDM kit configuration
Power Outputs
The PDMs offer four different Power Outputs Levels:
Power outputs
Each output provides status feedback for open circuit, short circuit, high temperature, over current, under voltage and over voltage. Inrush current, number of fault retries and the time between retries are all definable.
All the outputs may be configurable as PWM and allow soft start/stop.
For every output, a multicolour LED shows the status:
  • Enabled/disabled
  • Activated or not
  • Fault
Individual power outs can be configured with an easy-to-use visual interface.
Power Inputs
PDMs feature the following Inputs channels:
inputs diagram 1
inputs diagram 2
GPS Module
PDM comes with 4,000 tracks in their database and automatically select the one you are driving on, in order to calculate Lap Time when you pass the start/finish line.
Data Logger
An internal data logger is available, capable of recording all the analogue inputs, digital inputs, ECU channels, GPS values, Currents, status of all the Power Outputs. Here an example of what the recorded data may show, during engine cranking.
In red, the ignition push button
  • In blue, the battery voltage drop
  • In purple, the current absorbed by the solenoid
  • In dark green, the current absorbed by the fuel pump
  • In green, RPM Value
  • PDM32 – including a built-in 4GB data logger and dash controller
  • Display: 6” or 10”
  • GPS Module for automatic Lap Time and track position
  • Plugs to Build the PDM Harnesses
