AiM RPM Coil Adapter Motorcycle
SKU:
MXL-RPM-A - X05ADRPMM30
£65.00
Aim RPM-ECU Motorcycle Coil Adapter – ARP03
RPM ECU coil adapter AiM is a filter that allows to sample RPM signal from the coil and the ECU avoiding possible signal instabilities or wrong sampling due to electrical interference that can lead to voltage peaks – or to an RPM signal whose square wave is not perfect. AiM adapter cleans the signal from undesired peaks and squares the signal wave form.
X05ADRPMM30
