Aim Single-Point IR Temperature Sensor CAN Output PCB Assy – AimShop.com
SKU: IRTS-SP-PCB
Availability: 30 in stock
£65.00
QTY:
Trust Badge
Aim Single-Point IR Temperature Sensor CAN output PCB assy
Aim Technologies single-point infrared sensor is designed for non-contact temperature measurement in Motorsport and automotive applications. Common uses include the temperature measurement of tyres, asphalt, and cabin interiors.The sensor is capable of measuring temperatures from -70 to 380˚C, using CAN 2.0A protocol, and priced to be affordable to all tiers of Motorsport.
The sensor is offered as a PCB assembly, without an enclosure, amounting to a significant reduction in cost and allowing the end user to package the sensor according to their specific needs.
SENSOR SPECIFICATIONS
  • Temperature Measurement Range, To -70 to 380˚C
  • Package Temperature Range, Tp -40 to 85˚C
  • Accuracy < ±1% Full-Scale (typ. ±1.0˚C )
  • Noise Equivalent Temperature Difference, NETD 0.18˚C
  • Field-of-View, FOV 35˚
  • Sampling Frequency 8Hz
  • Spectral Range 8 to 14 μm
ELECTRICAL SPECIFICATIONS
  • Supply Voltage, Vin 5 to 8 V
  • Supply Current, Is (typ) 30 mA
Features
  • Reverse polarity protection 
  • Over-temperature protection (125˚C)
MECHANICAL SPECIFICATIONS
  • Weight < 2 g
  • L x W x H (max) 28.7 x 15 x 10.2 mm
