Aim SmartyCam 2.1 & 2.2 GP HD Roll Cage Mount for Kart (V Bracket)
£70
SmartyCam GP HD Roll Cage Mount. SmartyCam Roll Cage Mount to connect your camera to your Kart. Key Features: Ball...
Key Features:
  • Ball & Socket system
  • Secure roll bar mounting
  • Dual Swivel
  • Free Race Studio 3 Download
  • Securing Clip
The AiM SmartyCam GP HD, roll cage mount is made from anodised aluminium designed for mounting the AiM Smartycam GP HD lens on a kart frame.
The V bracket adjusts using a ball and socket system for optimum positioning and simply clamps to the roll bar, railing or tube.
The dual swivel joint makes viewing angle adjustment quick and easy.
The securing clip has a rubber lining to prevent slipping and any vibrations effecting the display.
This kit includes two tube clamps, 44mm & 55mm to enable you to attach the mount to different size roll bars, railings or tubes.
User Guide
Technical sheet
