SmartyCam GP HD Roll Cage Mount.
SmartyCam Roll Cage Mount to suit Solo 2 & Solo 2 DL.
Key Features:
SmartyCam Roll Bar Mount |
The AiM roll bar mount (V Bracket) to suit the Solo 2 & Solo 2 DL has been designed to securely mount the Solo 2 & Solo 2 DL to your bike or car. The V bracket adjusts using a ball and socket system for optimum positioning and simply clamps to the roll bar, railing or tube.
The dual swivel joint makes viewing angle adjustment quick and easy. The securing clip has a rubber lining to prevent slipping and any vibrations effecting the display. |
This kit includes two tube clamps, 44mm & 55mm to enable you to attach the mount to different size roll bars, railings or tubes. |
